Choke loaded PSU versus VR tube regulated PSU?
Old 19th March 2008, 06:59 PM   #21
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
Originally posted by G
The current draw will be 5mA per side and since it is a class A there is not going to be much variation in the load.
Would you be interested in an independent shunt regulated supply for each side? It is certainly an upgrade, but does consume more DC current since you need to drive two VR tubes instead of just one.
Old 19th March 2008, 07:04 PM   #22
G is offline G  United States
G's Avatar
Sure. I would be interested. About the supply you designed. I can use a transformer with a higher voltage rating and use more RC sections hence more filtering before the VR tube. I will draw up the schematic for the preamp when I get back from physical therapy. I'm currently recovering from a broken leg. I don't mind elaborate designs so don't hold back on my part.
Gavin
Old 19th March 2008, 07:52 PM   #23
zigzagflux's Avatar
Hope the leg heals well. I certainly won't hold back on the design. The beauty of this method, IMO, is that lots of filtering prior to the CCS is completely unnecessary. Less truly is more, in this case. I would not recommend additional RC sections, as they will do nothing to improve the very low ripple present across your VR tube. They may even add to instability, so I would leave this simple topology as is, and only play around with the values.
It sounds like you haven't purchased any parts yet? If so, I would suggest the following modifications:
Increase the transformer voltage and current. Maybe a Hammond 363CX or better (don't know if you need the 6.3V windings for your 6SN7's). Regardless, a little more voltage will help with flexibility, and more current is always a good thing. But we may get this one to work as specified. To be honest, I'm not a huge fan of Hammond iron; it throws out a lot of audible and magnetic hum that messes with my audio xfmrs. Frustrating.
Definitely go with separate CCS and VR tube for left and right channels. Minimum of 10mA through the VR, but no need to go up to 20mA. Eases the requirements of the rest of the power supply.
Once you get this far, and determine what xfmr you go with, we can discuss stability. As a precursor, it looks to me like 3.3uF for C1 and 27uF for C2 is a great combination. But based on the potential changes above, these values will be refigured.
Old 19th March 2008, 09:52 PM   #24
G's Avatar
So you are wanting to use a single power transformer with a separate choke and VR tube per channel correct? I have a rather large potted transformer that I could use although the voltage is 300 - 0 - 300 @150mA. Just slight overkill there. What do you think? I even have 4 40uF motor run caps, along with the afore mentioned transformer, that I have been saving for a 2A3 amplifier that I may or may not build one day. I also have 2 20H chokes(Hammond) rated at 100mA with a DCR of 181 ohms. BTW thank you for for your comment about the leg. It is healing fine. It's just taking it's sweet time about it.
Gavin
Old 19th March 2008, 10:11 PM   #25
G's Avatar
BTW here is the preamp circuit. Pretty simple and to the point. I kept the voltages low so that I did not need to use a seperate filament winding for each stage. I can bias the filaments to 80v or so and still be within the 6SN7s specs for heater above cathode voltage.
Gavin
Old 20th March 2008, 01:25 AM   #26
zigzagflux's Avatar
I would propose one power transformer, one choke, two CCS, two VR tubes.
Here's what I came up with. In order to get some control of the amount of distortion on the secondary voltage, I reduced the VR current to 13mA, which is still a good number.
How's that look to you? It's tight, but it works.
Old 20th March 2008, 01:37 AM   #27
G's Avatar
What are the specs of the power tranformer? Is it still the 396BX? The results certainly look good.
Gavin
Old 20th March 2008, 01:40 AM   #28
G's Avatar
What are you referring to when you say CCS. I have a couple of the IXYS current regulators you spoke of.
Gavin
Old 20th March 2008, 02:29 AM   #29
zigzagflux's Avatar
The 369BX, yes. Things are tight, but it should work. In my experience, Hammonds are marginally rated, but you should be fine. Ideally, you want to measure the xfmr parameters before buying the capacitors, in case slight tweaks are necessary. Fortunately, the sizes of the capacitors are small enough that you could afford metallized film throughout (or maybe use one of those 40uF motor runs).
Niiice. I use them myself. CCS=Constant Current Source. Subjectively, the IXYS work better in power supply applications than the DN2540, though I'm sure many will disagree. I also prefer the single device CCS over the cascoded in power supplies. Again, I may be alone in this opinion.
Old 20th March 2008, 03:13 AM   #30
G's Avatar
I don't suppose you could draw out a shematic of the proposed supply could you? I'm not quite sure how to utilize the IXYS current regulator. Do I put it in series with the OD3 or in parralel with it?
Gavin
Choke loaded PSU versus VR tube regulated PSU?Hide this!Advertise here!
Choke Loaded Zen hacknet Pass Labs 28 11th March 2017 10:54 AM
Trouble choke loading tube in regulated supply phrarod Tubes / Valves 19 14th June 2009 06:13 PM
Choke loaded LTP jane Tubes / Valves 6 8th November 2008 02:25 PM
Choke Loaded ZenV8 RAM Pass Labs 2 30th September 2006 02:01 AM
How to design the straight load line for choke loaded tube ? Antonio Tucci Tubes / Valves 14 30th March 2005 10:05 AM
