diyAudio Sponsor
Old 15th March 2008, 08:39 PM   #1
SpreadSpectrum's Avatar
Default peculiar Fisher circuit
I have attached an image of a post tone control gain stage and the phase inverter for a Fisher X-101-B. I was curious what the purpose of R1 and R6 are.
It seems like they would reduce degenerative feedback (by a controllable amount) in the gain stage across all frequencies equally, which would be an advantage over bypassing with a cap I guess. Its less efficient on the power, though.
Why would you do this in a cathodyne?
Anyone else ever see this before?
Old 15th March 2008, 08:47 PM   #2
sorenj07's Avatar
http://www.imageshack.us/
thumbnail for forums 1.
Old 15th March 2008, 08:50 PM   #3
Oops forgot to attach the image.
Old 15th March 2008, 09:00 PM   #4
That's kind of embarrassing. "Hey everybody, look at my circuit that you can't see.."
Old 15th March 2008, 09:40 PM   #5
tubewade's Avatar
Think nothing of that. Happens to all of us at one time or another.
Those resistors will shift the operating point of the valve. They will raise the voltage at the cathode making for greater reverse bias. I've seen this setup used in some circuits that have lower than optimum B+. I, too, would be interested in what other effects this might have on the operation of those stages.
I have a Harman Kardon and a Motorola amplifier that both use a similar configuration.
Wade
Old 15th March 2008, 09:46 PM   #6
Well, in this amp there is more than adequate B+ for 12ax7s. Why not just use a more optimal Rk? I'm thinking they were looking for less cathode degeneration here.
The cathodyne stage is what's got me here. It seems like they just made it more complex for no real reason. I can't think of a benefit for R6.
Old 15th March 2008, 10:14 PM   #7
SY's Avatar
Besides increasing bias slightly, they also provide some ripple cancellation.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th March 2008, 10:52 PM   #8
Maybe that was their reason for it.
They eliminated these resistors in the X-101-C.
Old 16th March 2008, 03:05 AM   #9
diyAudio Moderator Emeritus
ray_moth's Avatar
Yeah, that's probably it. The cathodyne is notorious for its poor PSRR (a fact that seems to have concerned John Broskie quite a lot).
Old 16th March 2008, 03:17 AM   #10
Miles Prower's Avatar
Yeah, that is very strange. It looks like the designer didn't know that a cathodyne is inherently self balancing. Sure, they didn't have laser trimmed, precision, +/- 1% metal films back in "the day", but still, looks like way too much trim pot there for balancing the +/- 10% C-comp resistors used quite commonly then.
There are no foxes in atheistholes
www.dolphin-hsl.com
Fisher X-101-D bsgd Tubes / Valves 6 27th April 2009 08:05 PM
fisher xp 60c tim614 Multi-Way 0 6th July 2008 02:51 PM
FS: Fisher KX-100 speaker Swap Meet 1 12th May 2007 10:14 PM
very peculiar psu problem Jaap Tubes / Valves 13 10th February 2007 07:48 AM
Peculiar Sovtek EL34 bevaviour ray_moth Tubes / Valves 12 15th April 2005 03:04 PM
Page generated in 0.09565 seconds (78.29% PHP - 21.71% MySQL) with 11 queries
