diyAudio Sponsor
Old 16th March 2008, 01:39 AM   #11
tubelab.com's Avatar
The neon light bulbs have characteristics like a bipolar zener diode. They will draw no current until the neon inside ionizes (it lights up) and then they exhibit a constant voltage characteristic similar to a gas regulator tube. The ordinary NE-2 variety were designed for use as indicator lamps, an do not have well controlled specs. There were special versions made to have well controlled voltage breakdown characteristics. These were used in timing generator circuits by Tektronix and others.
They have found their way into various electronic circuits over the years, and can even be found in vacuum tube amplifiers as sonically benign voltage clamps or limiters. Look at the schematic of Kevin's 300B P-P amp.
They were used as relaxation oscillators, but in an organ they were often used as the frequency divider using a "locked relaxation" oscillator design. If all of the notes on the keyboard play at the correct pitch, don't mess with it. It is hard to get these circuits working right if you start changing parts.
Mouser lists several flavors of NE-2 lamps with voltages of 65 and 95 volts at several currents.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 16th March 2008, 02:51 AM   #12
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I know in some organs (namely German Ionika) neon lamps were mounted near a wire with HF that was shielded by shield on keys. When some key was pressed shield gradually opened HF radiation so a lamp started conducting; such a way organ type attack / decay were simulated.
http://www.vermona.de/htm/ionika.htm
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Christmas Eve 7N7 Tubes / Valves 33 25th December 2007 09:00 PM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
Christmas greetings Jim Karr The Lounge 4 25th December 2005 01:46 AM
Christmas is here! Corn-Picker Everything Else 20 28th December 2002 03:27 AM
Page generated in 0.07495 seconds (71.40% PHP - 28.60% MySQL) with 10 queries
