diyAudio Sponsor
Old 13th March 2008, 02:45 PM   #1
Guiness is offline Guiness  United States
Guiness's Avatar
Default 3C24SE amp...
Was checking out Valve World last night and came across this amp...
Just curious as to what you guys think of this circuit.
Guiness
Old 13th March 2008, 03:21 PM   #2
Fuling is offline Fuling  Sweden
Looks like a version of Shishidos "Dynamic Coupling". Should work fine, but personally I would choose a driver tube with lower rp and higher gm.
Old 14th March 2008, 08:28 AM   #3
316a is offline 316a  England
316a's Avatar
Default Re: 3C24SE amp...
Built a similar amp last year . Used 3A/108A input stage and 6AH4 driver . LCL DC filaments all round (only ac for the 6AH4) , feedback implemeted anode-to-anode between input and output valve , also the output transformer secondary was in the cathode circuit of the 3C24 . It sounded pretty good but never made it past breadboard stage , the 3C24 is an impressive looking valve running full cherry One point to note is that A2 amps sound very bright and can sound unusual on bass reflex speakers . If attempting a similar amp , the grid and plate dissipaters need to be used
cheers
316a
Old 14th March 2008, 08:38 AM   #4
316a's Avatar
schematic
Old 14th March 2008, 02:25 PM   #5
Guiness's Avatar
I ran across 6 of these tubes the other day while I was re-arranging some boxes and thought they would make a pretty good amp. I will start gathering up some parts and try acouple different circuits.
Will post some pictures soon.
Thanks guys
Guiness
Old 14th March 2008, 03:02 PM   #6
316a's Avatar
Thanks guys
Don't forget the heat dissipators ! These won't last long otherwise . Also run the filaments for a few hours to clear any residual gas as these are self-gettered (anode is coated with the getter material)
cheers
316a
Old 14th March 2008, 09:45 PM   #7
coresta is offline coresta  France
coresta's Avatar
Hello 316a , how do these DHT die ? or when are they dead ? filament failure or something else ? i have some HK54 and VT127a left . They're not new , they light on but i dunno about the vacuum . Should a sherry red heating of the plate clean them new ? cheers Pierre
Old 14th March 2008, 10:34 PM   #8
316a's Avatar
The weak points of all those valves are the seals . If the seals get too hot then air gets in and it's game over for the valve . I have over a dozen VT127A and there are a few really gassy ones so these could probably do with a good baking either in the oven or by lighting the filament . Incidentally it's a nasty one to light up and will need DC , you will need some huge chokes for the filament supply , regulators , resistors etc just drop too many volts . HK54 are a handsome valve , I've some of these but never used one , the same will apply , bring them up slowly on a variac and run the fils for a few hours . Better still run your HK54 and VT127 from an external filament supply and run on a valve tester using the filament as the cathode connection . From memory the VT127 should have gm of around 1.8mA/V at 0V / 400V . See picture for a messy breadboard using VT127 , the chokes at the back are the LCL filament supply
cheers
316a
Old 14th March 2008, 10:51 PM   #9
coresta's Avatar
for sure , they go hot hot hot , even after 5 minutes . I have done black clips from ... transistors coolers Do you think these are worth the effort ? Not with AC heating ? huh ? ! best regards
Pierre
Old 15th March 2008, 12:43 AM   #10
316a's Avatar
Pierre
You can try with AC heating , I could not completely remove the hum though . VT127 will be more robust than the 3C24 without dissipators . Get yourself some HR6 caps for the 3C24 which are only $5 per piece (Google it , think it was Nebraska Surplus who had some) . My father turned me some caps for the VT127 , I'm sure you could drill out an HR6 to suit otherwise
cheers
316a
Page generated in 0.10159 seconds (81.41% PHP - 18.59% MySQL) with 10 queries
