| diyAudio Sponsor | ||
#11 |
They work like a switch. They are either on or off, and once they are on they stay on until B+ is removed. They are the vacuum tube equivalent of an SCR, or half of a Triac. They do glow purple when they conduct.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#12 | |
I'm building a version of the Tabor circuit with those valves - i would be interested in how your using yours. Got to the build stage with mine - should be about a week before I have any results. Shoog |
#13 |
Hmm well from research I did it seems it's a mercury tube and it glows blue, and I don't think I'm really too competent in designing a circuit for it or even if I'll get much benefit out of it. My amplifier is essentially done and it's a bit too much of a hassle to incorporate this into it. I've never worked with tube regulation for power supplies. Hopefully I'll have my new amp fired up in a day or two.
| Homemade Vacuum Tube | dhaen | Tubes / Valves | 50 | 13th July 2011 05:48 PM |
| WTB: Vacuum Tube Tester | mrdon | Swap Meet | 0 | 22nd May 2009 04:01 AM |
| The Vacuum Tube Truth | Serratoga | Tubes / Valves | 31 | 29th November 2007 09:25 PM |
| Vacuum Tube Pre O.C.L. | gianmaria | Tubes / Valves | 13 | 16th February 2006 06:32 PM |
| DIY Vacuum tube amp | turbo_h4 | Tubes / Valves | 2 | 1st July 2004 01:48 AM |
| Page generated in 0.07343 seconds (69.00% PHP - 31.00% MySQL) with 10 queries |
