| diyAudio Sponsor | ||
#11 | |
400E or EL (L=log meter movment) good to 10Mhz 400F or FL good to 4Mhz & has a swichable low-pass filter. 400G or GL good to 4Mhz 3400A true RMS good to 10Mhz. Option 1 on any of these is dB scale on top. 427A multi function AC/DC/volts/current/ohms. (1 Mhz) Battery only. option 1 gives both AC line operation or battery (22v) For any of these meters, be sure to get a late version. Stay away from the old blue/gray color and get the mint green/tan color. Especially for the 3400A. The older choppers and thermal couplers inside (3400A only) get flaky with age. Kikusui and Leader from Japan makes a decent instrument. Boonton 93A is very good. Ballantine 323 or 3015A not bad either. Some of the very old Ballantine 300 series (tubes) were nice meters in their day. They're real cheap now but need restoration. Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#12 |
In the UK you may be able to pick up some ex-BBC test equipment such as their EP14/1 (analogue meter), or (if you're really lucky) the old Neutrik analogue test set.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#13 |
Fluke 8920A -- a thermally responding meter like the HP3403C -- they can often be purchased for $20 or so on EBay.
#14 |
I like the HP400E- very trouble free but not true rms. The HP3400s are also good, true rms, but not nearly as reliable. I don't use either one as much these days, relying on digital bench meters, or the scope. AC analog meters are great for peaking things up or measuring nulls, but the inability to see just what you're measuring is a great weakness. Is it signal, or is it noise? There was also a Heathkit AC voltmeter, very similar to the HP400, that was actually quite good- the IM-5238.
I used to be an audiophool like you but then I took an arrow to the knee. |
#15 | |
I have an "in-cal" HP function generator and the Fluke 8920A and HP3403C are about equal. I don't know why prices for the HP3581 wave analyzer have spiked so much -- these have a very good RMS detector and are very acurate to 50kHz -- and will measure down to some tens of nano-volts -- but there's a Genrad model out there as well. |
#16 | |
Thank-you all again, for your help.
Much appreciated The thing is, I've got a distinct disadvantage to most of you; I'm in the UK; so finding anything remotely useful over here can be either highly unlikely, very expensive, or both! There is a chap on ebay selling HP3400s for £45. I do like Heathkit stuff, I've got some here, but it's harder to find over here. Is true-RMS really necessary? The Fluke 8060a looks like a candidate; according to tubebuilder:- http://www.tubebuilder.com/testeqreviews.html#fluke8060 Quote:
#17 |
| Looking for a LED voltmeter circuit | DolbyR | Equipment & Tools | 9 | 9th May 2006 07:31 AM |
| DIY RMS Voltmeter? | Stocker | Equipment & Tools | 7 | 5th January 2005 11:28 PM |
| Making LED voltmeter | Dima | Equipment & Tools | 5 | 3rd August 2002 01:11 PM |
| Page generated in 0.09211 seconds (79.17% PHP - 20.83% MySQL) with 10 queries |
