diyAudio Sponsor
Old 14th March 2008, 01:07 AM   #21
MQracing's Avatar
here is a neat article from a radio guy--- showing several different transformer based phase splitting strategies. It's a easy and fun read to boot.
http://www.philcoradio.com/tech/audio.htm
Old 14th March 2008, 12:22 PM   #22
alexg is offline alexg  Philippines
alexg's Avatar
Originally posted by MQracing
The 'compact' version of Yeo's that you tried--- how did you tie down the cathodes? which output tubes did you use?
Your the first person I've heard who has tried both ways. And I find it encouraging that you liked the results of each approach.
Next week I'm stacking some remaining Z-565 coils that I have--- pp guys for EL84's with UL taps--- I'm going to have to try the compact myself after admiring it for such a long time on paper.
Did you try Yeo's circuit with the EL-84 triode as the voltage amp?
If so--- was it quiet enough? Other feedback I've gotten from people is that the EL-84 T is noisy when used as a small signal
driver tube.
In terms of simplicity--- the compact is hard to beat. And if your on a budget at all it would seemingly also recommend itself highly.
msl
I used the 832A tube with a common cathode for both tetrode on each envelope when I tried both the compact circuit and a center tapped choke phase inversion.
I have not tried Yeo's circuit using the EL84 as voltage amp.
But I might do a DC coupled EL84 into a 2a3 as done by Torsten Eisenberg. I am just weighing my options, since I need a 455-0-455 power transformer which is quite expensive.
I am also trying the compact circuit on an EL34, triode strapped, cathode biased PP amp (I am doing an SE EL34/KT88 for a friend based on Mikael Abdellah's circuit and before wiring it as an SE, I will try wiring it as PP using the compact circuit and see what happens).
Old 14th March 2008, 02:44 PM   #23
Jaime is offline Jaime  Uruguay
Jaime's Avatar
Here are a beautiful amplifier with EL84 in small signal.
http://www.veiset.net/PX25/worklog.html
I write in English worse than Tarzan
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
Choke input 3 phase rectification voltage? Tweeker Power Supplies 5 13th January 2006 05:08 PM
Choke coupled phase invertor Tubes4e4 Tubes / Valves 2 27th December 2005 09:18 AM
dipole sub H-Frame, phase or opposite phase ? mbon Multi-Way 6 19th June 2004 08:36 PM
Page generated in 0.07142 seconds (73.08% PHP - 26.92% MySQL) with 10 queries
