Safety ground question
Old 11th March 2008, 12:00 AM   #11
koolatron is offline koolatron  United States
NEXT question...! In attempting to determine the secondary voltages of a more-or-less unknown transformer (Identities of the filament windings, etc, are known; voltages aren't), I measured ~725VAC unloaded across the HV secondary.
Buuuut that's unloaded volts. What's the likely actual secondary voltage of this little guy?
(thanks for all the help up until now, by the way)
Old 11th March 2008, 12:25 AM   #12
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Measure the resistance of the windings, plug into PSU Designer, and you'll know. If you don't have the program, download from duncanamps.com
Old 11th March 2008, 12:48 AM   #13
oh, cool! Shoulda done that before I left the house. Fooey!
Thanks again!
Old 11th March 2008, 05:35 AM   #14
Arright - tinkering anew this evening, I've decided that this is probably a 720VCT brick - probably overkill and a half for the little Aikido linestage that I'm in the process of putting together (from a kit - I don't have that much faith in my own ability yet )
This thread is straying further and further off topic - I should probably start a new one - but does anyone have a quick link or pointer on how to get a ~300VDC B+ voltage out of this guy? I've been playing around with PSUD II, but I'm not sure what kind of load the Aikido imposes, and dropping necessary volts across a resistor obviously makes the final B+ voltage sensitive to loading.
Is this one of those "put it together and play with the values" situations? I don't want to blow anything up.
Safety ground questionHide this!Advertise here!
connecting audio ground to Safety Earth AndrewT Power Supplies 41 30th May 2011 10:50 AM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Safety question concerning ground loops derMichi Chip Amps 5 9th June 2006 08:31 AM
Ground and Safety danielle Everything Else 10 18th February 2006 07:53 AM
Alternative safety ground sobazz Solid State 13 4th September 2003 01:03 PM
