Extry, Extry, Blind Squirrel Finds Nut -sequence
Old 10th March 2008, 12:43 AM   #1
mashaffer is offline mashaffer  United States
Default Extry, Extry, Blind Squirrel Finds Nut -sequence
...film at 11.
Here is proof that even a blind squirrel eventually finds a nut. I had made it known on the freecycle boards that I was always interested in old audio equipment. I was contacted by a young lady that wanted to get rid of a record player console. So Nan and I had lunch out after church today and then stopped by for a look see.
It didn't look like all that much and they knew nothing about it except that they had paid $75 for it a few months ago at an antique shop down the road. They said that it worked but had recently developed a "crackle" in one speaker. We turned it on and listened to it for a minute or two on the radio setting. It actually sounded pretty decent with no hint of the tinniness one often hears from such units. In fact it sounded a little bit light on the top end. I also noted no crackling.
Old 10th March 2008, 12:44 AM   #2
Even though it was probably solid state, I figured that since it was free I might as well take it as I could always use the speakers and switches etc as salvage so we loaded it up and headed home.
Now I should have had a clue that something was afoot when he turned it on and we didn't get sound right away. However, he was fiddling with the tuner at the time so we may not have been on a station. When we finished it was tuned to a station that I knew that we could get at home.
Old 10th March 2008, 12:46 AM   #3
When we got home I took it into the garage and plugged it in. Again it didn't come on right away. Hmmm... It did come to life in a minute or so and so I left it run while I got Nan out of the car. After a few minutes I started to hear some crackling so I turned it off. It faded away gradually. Hmmm... again. Now I am starting to get suspicious.
So I began removing the back cover. I saw a glint of something. I quickened the pace and got the top and side screws out pulling the back gently out when what to my wondering eyes should appear but a pair of small bottles and a big silver can cap. And what is this? Too many transformers for a cheap old solid state console.
Old 10th March 2008, 12:49 AM   #4
flyinglemur is offline flyinglemur  Canada
That's a diddly little amp if I ever saw one! Should clean up a cracker
Old 10th March 2008, 12:50 AM   #5
It turns out I just scored a nice old Vacuum State console with SE outputs. Sweet. Now I just need to confirm that it is not collectible before proceeding. Model number is VFR19M Serial number appears to be 1460891-1-1
Output tubes are 6BQ5.
Old 10th March 2008, 12:52 AM   #6
The preamp/tuner section lists...
AF Amp 12AX7A
FM Limiter 6AU6A
2nd FM IF Amp and AM Det 6BA6
1st AM & FM IF Amp 6BA6
AM RF Amp 6BA6
AM Conv 6BE6
FM RF Amp and Conv 6C3
Old 10th March 2008, 12:54 AM   #7
I could read the stampings on one of the OTs and it read
962628-11
1-606-4-07
The can cap is 80, 40, 10, 150
I didn't hear much in the way of highs so the tweeters or caps may be blown. I have not pulled anything yet to measure speaker imp.
Old 10th March 2008, 12:56 AM   #8
I may be preaching to the converted, but find a schematic and crossreference values original vs measured?
Do the usual, check connections etc. Does your Multimeter have capacitance readout?
Old 10th March 2008, 01:00 AM   #9
Will be searching but I will trace by hand if needed. Recapping is a given of course. One correction that last tube should be 6C9 not 6C3.
mike
Old 10th March 2008, 01:02 AM   #10
Sounds like duff connection/cap somewhere if it's crackling. Broken down electrolyte produces such noise
Extry, Extry, Blind Squirrel Finds Nut -sequenceHide this!Advertise here!
Behringer XO sequence rick57 Multi-Way 6 11th October 2006 06:07 AM
my parts finds theChris Everything Else 0 8th July 2006 11:48 PM
What should be the sequence.... bimbla Everything Else 2 23rd March 2005 11:55 AM
Anybody finds threads like this useful? Peter Daniel Everything Else 9 10th June 2003 03:54 AM
