tube amp being weird -- any ideas - Page 2 - diyAudio
Old 11th March 2008, 06:51 PM   #11
RIP
pedroskova's Avatar
Have you swapped the KT88's between channels?
Old 11th March 2008, 07:49 PM   #12
soundbadger's Avatar
yep, i have also tried some el34's and same problem.
i have also changed the pre-amp tube i have tried 6n1p and e88cc in there. still the same problem.
Old 12th March 2008, 12:30 AM   #13
pmillett's Avatar
Originally posted by soundbadger
THE BIAS VOLTAGE APPEARS TO DROP ON ONE CHANNEL WHEN THE PROBLEM IS occurring.
Most likely is that either the coupling caps are leaking or the grid resistor is too large (see above). Both cause the grid voltage to drift above 0V.
the bias resistors are also pretty hot, i measured them about 70 degrees centigrade
70C is not hot for a power resistor. that's it's job - to turn electric energy into heat. Many WW resistors are designed to run at at 150C or higher when operated at rated power.
Pete
Old 12th March 2008, 01:08 AM   #14
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Try temporarily replacing your coupling caps to the output valves. I've had near new ones that failed.
Ideas for SE amp with this tube Pentium100 Tubes / Valves 13 14th December 2011 02:21 PM
Weird old power transformers (filament, SS and tube) - $7 each! pjanda1 Swap Meet 6 29th March 2010 04:17 PM
tube hum in a 6SN7 Aikido - is this weird? cbutterworth Tubes / Valves 16 12th March 2007 04:52 PM
Ideas for a tube that heavily distorts ? jim Tubes / Valves 8 3rd July 2006 02:32 AM
Need ideas for a music only tube sub. J.k.Wilson Subwoofers 4 18th September 2005 03:50 PM
Copyright 1999-2017 diyAudio
