What are the liabilities of running 5.3 volts DC on 6SN7 filaments?
Gavin |
#2 |
Lower gm, higher rp and shorter lifespan
#3 |
If you don't run them very conservatively, you can deplete the space charge and damage the cathode.
See: http://www.diyaudio.com/forums/showt...80#post1441880 |
#4 |
Thanks for the answers. I was just curious.
Gavin |
#5 |
Let me guess - you are rectifying a 5V winding originally intended to supply the tube rectifier heater/cathode.
I've done this myself BUT using schottky diodes. In the amp concerned, a 5V 2A winding with schottky diode bridge and 10,000uF/25V electrolytic pushed 5.95V DC into a 12AX7 heater (0.3 Amps draw) very nicely. I used 4 off 1N5822 (40 Volt 3 Amp) schottky diodes for the bridge. These things aren't real cheap but when I looked at replacing 2 of them with a MBR20100CT (dual 100V 20A with common cathode in a TO-220 pack) to save some bucks I found that the voltage drop was significantly higher. Looking at the heater supply with a CRO (in circuit with the whole amp running) I did see a few small spikes projecting out of the ripple which went away when I sat the whole supply on a +60V DC supply derived from the main HT. Heater Voltage Specification is +/- 5%. 6.3 - 5% is 5.97V. As far as I'm concerned the 5.95 is "in spec" (ish) whereas 5.3 is not. Cheers, Ian |
| filament AC vs DC | yourownfree | Tubes / Valves | 26 | 16th April 2008 05:51 PM |
| Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 01:06 PM |
| DC filament | guitvinny | Tubes / Valves | 5 | 16th October 2006 02:15 PM |
| 2A3 AC filament hum | bigbulb | Tubes / Valves | 4 | 28th July 2005 12:59 AM |
