| diyAudio Sponsor | ||
#11 |
I have used 866A's in power supplies and have not had any issues. The precautions concerning these tubes must be adhered to, but this is true of any device... a little common sense goes a long way.
I have a Taylor 866A that is beginning to "flake inside", but what do you expect after 60 years? I'll turn it into a desk monument with a piece of wood and urethane. |
#12 |
Banned
I like them because they sound better than the standard rectifier tubes that I have used. They need to be warmed up for at least a minute or so before B+ is applied, but this can be done thru a relay or manually. I guess I am a bit of a dare devil. I can not see mine as they are in a cage, but that is not why I like them. I like 866A's tubes because of ther sound :-)
#13 |
I don't think quicksilver rects are worth the hassle.
If you need low voltage drop at un-insane voltages, dampers. If higher voltages, xenon rects. Of course they don't look as badass. But you don't have to worry about ambient temp, warmup time, dropping the tube, etc etc |
#14 |
Or the RF hash and noisy switching. I've always wondered if the inherent noise of mercury rectifiers was one of the attractions- some poor designs can benefit from a little dither, even if unintentional.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
| delay on for 83 mercury vapor | ecir38 | Tubes / Valves | 1 | 15th June 2008 11:18 PM |
| mercury vapor... i love it!!! | x84andrea | Tubes / Valves | 45 | 26th November 2007 11:51 PM |
| 966 mercury vapor rectifier | Dave Cigna | Tubes / Valves | 2 | 10th February 2006 09:41 PM |
| mercury vapor rectifier tubes on e-bay | karma | Tubes / Valves | 10 | 19th June 2005 02:52 PM |
| Page generated in 0.08111 seconds (73.90% PHP - 26.10% MySQL) with 10 queries |
