Lowrider said:It works again, thanks...
But I still dont know how to measure ripple...
http://basaudio.net/pubs/DIY_2006_1.pdf
page 11
Lowrider said:Obrigado,
But I cannot understand how they change the view to see that detail ???
To zoom in to a selected area: Hold down the left mouse button to "draw" a square of the area to zoom into. Or use the zoom buttons to zoom in/out.
To pan the plot: Hold down your right mouse button and drag the wiew area around.
Svein.
Svein_B said:
You need to set the delay time in seconds (second box), and not increase the simulation period.
SveinB.
For the attached circuit, and 1sec delay, diff for C4 point = 67.530. Way too unreal. What are the constants to be set for real ripple results?
SveinB.
I usually set the sim time to something small, too, to get a good look at the wave form. Here's an example: http://www.diyaudio.com/forums/showthread.php?postid=1438047#post1438047
just a little resurrection of original topic..
i'm in similar situation as original poster, technically more-less knowing PSU attributes, but the question of ideal value has been unknown to me (i know the best is to try and hear)
i can see that for example on Russian/Bulgarian etc. forums there is a convention of monstrous values in PSUs, often tens of thousands of uF, the final cap as well, practically on every schematic there. Here i can often see concerns about too attacky or bloated (or mid-high degraded) sound with 100-200uF.
I'd be glad to finally learn something about this.. thanks
- Tubes / Valves
- Capacitance in PSU
