preamp line ctt
preamp line ctt
Old 7th March 2008, 04:32 PM   #1
richwalters is offline richwalters
richwalters's Avatar
Default preamp line ctt
Glancing through my 1960's dusty amp files, I came up with this preamp circuit and lashed it up using modern components.
The 2nd stage ECC83 bootstrap is a bonus upping the input Z and with gain control in cathode, the 3rd stage uses AC (36dB) nfb strapped back to cath 2nd stage. I have to tabulate the b/w performance and other issues.
For those who can't abide with true signal triodes, I used two EF86's as triodes an by golly it gave the b/w results I was after. Even with ECC83 it's good.
1V AC rms in and 18V rms at 3rd stage at only 0.15% thd 2nd harm. The THD drops proportionally with level. With such dynamic overhead performance, this would make a template for a line amp and with a Baxandall tone control stage + cathode follower o/p an excellent piece of kit..
Noise level using EF86's as triodes typ -90dB (pretty quiet).
The 2nd +3rd stage physics is pretty obvious, but I've only seen this config in one other preamp. Why not ?
The only other preamp I've seen anywhere near this is the Old Brimar/Thorn VP10 using obsolete ECC807's.
richj
Anyone else tried sim ?
Old 7th March 2008, 04:34 PM   #2
parts list
preamp line cttHide this!Advertise here!
6V6 line preamp Salas Tubes / Valves 3376 17th June 2018 07:54 AM
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
