2A3 maximum plate voltage - Page 2 - diyAudio
Old 9th March 2008, 12:23 AM   #11
alexg is offline alexg  Philippines
alexg's Avatar
Originally posted by rdf
What load are you using in PSUD, alexg? Constant current loads result in unrealistic startup conditions. No tube pulls 100% design current at zero plate volts.
Am using 190 ma constant current load in PSUD2.
Old 9th March 2008, 06:39 AM   #12
rdf is offline rdf  Canada
rdf's Avatar
Consider trying an equivalent resistor and see if it still results in overcurrent. It's always wise to play it safe but it's still hard to believe a 5ar4 is hurting at 1/4 rated current and 1/4 rated first capacitance. Unless it's a Sovtek. =D
Ears aren't microphones.
Capacitors and maximum voltage ratings hilbert_mostert Tubes / Valves 13 9th May 2009 10:05 AM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 09:57 PM
Best plate voltage for 6dj8 at +-6ma npr Tubes / Valves 12 18th January 2009 03:47 PM
Maximum voltage for LM4780 G.L. Tirebiter Chip Amps 5 6th March 2005 10:06 AM
Maximum input voltage of LT1085 & LT1033 chengtaw Solid State 2 8th January 2003 04:27 PM
Copyright 1999-2017 diyAudio
