| diyAudio Sponsor | ||
found plenty of NOS alps 100K linear pots. i know i cant use them as volume pots but anybody had any idea if those can be used for tone controls? saw some schematic of tone schematic from my search here in the tube section but it also calls for 100K audio taper. so what do you think, throw those NOS ALPS lin pot away?
#2 |
don't throw it. check this web site
http://sound.westhost.com/project01.htm http://users.ece.gatech.edu/~mleach/lowtim/part2.html |
#3 | |
a tone control circuit using this 100K lin pots would be a nice project. if i can only substitute those for the 500K linear pots that is commonly used for tone controls... |
#4 |
Edrel,
I've attached a Max Robinson designed tone control circuit that uses 100 K Ohm linear controls.
Eli D. |
#5 |
oh thanks eli. this could be the perfect thing that i am looking for. 4 dual triodes for a stereo not a problem, at least for me
| WTB dual gang 16 mm 100K PC mount pots | chipco3434 | Swap Meet | 0 | 9th December 2006 01:44 AM |
| Looking for stereo 100k Linear potentiometer | dine1967 | Swap Meet | 2 | 25th May 2005 08:04 PM |
| i need 100k log pots | brian marshall | Parts | 2 | 30th July 2004 04:23 PM |
| 100K linear pot | annex666 | Swap Meet | 7 | 27th September 2003 11:13 AM |
| 100K linear cermet pots | HarryHaller | Swap Meet | 0 | 19th September 2002 07:18 PM |
| Page generated in 0.09730 seconds (65.68% PHP - 34.32% MySQL) with 11 queries |
