diyAudio Sponsor
Old 6th March 2008, 10:49 PM   #1
weinstro's Avatar
Default 6550, 6L6, or 6V6??
For a push-pull, Class AB1 amplifier, pentode connected, running cathode feedback, some GNB (circlotron, twin-coupled, or something else), what should I expect in terms of sound quality from each of these tubes?
If the system were to be bi- or even tri-amped, would your answer change?
OPT is undecided yet, but would be "high quality". Bias would be optimized for each tube. Speaker efficiency is such that Class A or triode isn't going to fly.
I'm just trying to gauge expected sonic quality under best circumstances for each tube.
Old 6th March 2008, 11:07 PM   #2
Ty_Bower's Avatar
You're not exactly comparing apples to apples, are you? I think the answer lies in how much power your speakers require. For push pull, I believe you're looking at roughly 60 watts, 30 watts, or 15 watts (6550, 6L6, or 6V6).
Not to mention the difference in price...
Old 6th March 2008, 11:49 PM   #3
tubelab.com's Avatar
A pair of 6V6's in pentode AB1 can do 15 to 25 watts depending on how hard you push them. NFB is required to tame the output impedance.
I can get 15 watts from a pair of 6550's in triode class A without any feedback. 30 watts is available in UL mode, again in class A, with little or no feedback.
As stated you need to consider your budget and how much power you really need (or want) and any preferences for amp type (triode, UL, pentode, and class A, or AB).
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
6550 se amp Chad Tubes / Valves 3 15th September 2011 05:48 PM
2A3 v 6550 rick57 Tubes / Valves 96 9th July 2005 12:54 PM
1.2k vs 2.5k TC on a 6550 amp? killerfishes Tubes / Valves 3 29th June 2005 02:38 AM
Wad 6550 Brap Tubes / Valves 6 20th January 2004 06:54 PM
Page generated in 0.05847 seconds (80.61% PHP - 19.39% MySQL) with 10 queries
