diyAudio Sponsor
Old 3rd March 2008, 09:46 AM   #1
bulgin is offline bulgin  South Africa
Default Tube Virgin
Hi Guys
Over the weekend, a friend gave me two boxes of tubes. If I may list some of them, are any good for an audio project or two?
Telefunken EBF 80
Telefunken 6BA6
Haltron EF93/6BA6
Mullard EF80
RCA 60EX0
Mullard EF95
Mullard EC92
Torvac 6AK5
RCA H2E
Sylvania 12BA6
Brimar 6AL5
Brimar EF91
Haltron 6C4
Brimar 6C4
Brimar EF91
Philco 7C5 (2 of)
Philips UCH21
And then there's a second box with
Mullard UCH21
UBL?21
Philco 787
Purotron? 7A7
? 7B5
RCA7A8
Philco 7C5
Philips UCH21
K-R 7C5
Zenith 7C6
Much obliged
bulgin
Old 3rd March 2008, 02:22 PM   #2
ilimzn is offline ilimzn  Croatia
OK let's see here...
EBF80 is a 6.3V heater dual diode + remote cut-off pentode combo, which is mostly used for IF and detector work in receivers. There is mention of audio amplification in it's datasheet at http://www.mif.pg.gda.pl/homepages/f...30/e/EBF80.pdf
6BA6 a.k.a. EF93 is another remote cut-off pentode used for IF work in receivers, doubtfuly of use for audio. Datasheet at http://www.mif.pg.gda.pl/homepages/f...020/6/6BA6.pdf in french.
EF80 is a very common pentode that can be used in audio, assuming you get a particular piece that is not microphonic. It's original use was for IF in receivers, so low microphonics were never a design goal, that being said, there are good ones out there. It makes a great driver tube or general amplifier, also great in triode mode.
Datasheet here: http://www.mif.pg.gda.pl/homepages/f...030/e/EF80.pdf
Triode mode curves here: http://www.tubes.mynetcologne.de/roe..._as_triode.pdf
EF95 is a pentode used for HF amplification. The datasheet is very short and does not mention if it is a remote or sharp cut-off type, nor does it give any curves, it is at http://www.mif.pg.gda.pl/homepages/f...030/e/EF95.pdf
EC92 is a single miniature triode which is actually a single section of the common ECC81/12AT7 double triode, commonly used for audio in various roles, datasheet here: http://www.mif.pg.gda.pl/homepages/f...010/e/EC92.pdf
6AK5(W) also known as 5654 or 6096, is a HF amplification pentode, that can be used for small signal linear amplification in pentode mode, or as a very nice triode, with mu around 30 and gm about 5mA/V. This datasheet also gives triode mode curves: http://www.mif.pg.gda.pl/homepages/f...138/5/5654.pdf
12BA6 is a remote cut-off pentode intended for HF work, audio use is dubious. Datasheet: http://www.mif.pg.gda.pl/homepages/f...093/6/6BA6.pdf
6AL5 is a miniature double diode, often used in radio equipment, and likely holds the dubious distinction of being the least usable tube for audio ever
Datasheet: http://www.mif.pg.gda.pl/homepages/f...093/6/6AL5.pdf
EF91 is also known as 6AM6, and it is a nice RF pentode also usable for audio - and it also makes a very nice liner triode, with a mu of about 70 and gm at about 7mA/V, which makes it eminently usable for a variety of applications in audio.
Datasheet here: http://www.mif.pg.gda.pl/homepages/f...154/e/EF91.pdf
Triode curves here: http://www.tubes.mynetcologne.de/roe..._as_triode.pdf
7C5 is a loctal socket version of the popular 6V6GT beam power pentode, which is a popular medium power audio output tube, which can also be used as a low mu triode for line stages.
Datasheet: http://www.mif.pg.gda.pl/homepages/f.../084/7/7C5.pdf
See also type 6V6GT
UCH21 is a triode-heptode with a loctal base, the usability of which is unfortunately limited by it having a common cathode. Still, the Philips darasheet shows audio amplifier and phase splitter applications, here:
http://www.mif.pg.gda.pl/homepages/f...30/u/UCH21.pdf
It can be used to build a push-pull ampifier front end, which works very well with a pair of UBL21 tubes for output. The slight drawback is the 100mA heater. which is intended for series connection in mains powered radio receivers, which makes for a 20V approximate heater voltage rating.
UBL21 as mentioned in the above paragraph is an loctal base output pentode + dual diode. This fairly rare tube holds an excellent output pentode of very high sensitivity, needing a very low input signal. Because of this it must be used with automatic bias only. The datasheet unfortunately gives only data for fairly low power rail voltages, because of the intended use of the tube, in mains powered radio sets. This also implies a 100mA relatively high voltage heater (55V). A push-pull pair gives about 13W from a 200V power supply at 4% distortion. That being said, some characteristics are remarkably similar to the very popular EL84 output pentode, so it is possible that this tube can be used under similar circumstances, with corrections to the biassing. The diodes in the tube were intended for demodulation in radio sets, and for audio applications are not used. Datasheet: http://www.mif.pg.gda.pl/homepages/f...30/u/UBL21.pdf
7A7 is the loctal socket equivalent of the octal 6SK7GT remote cut-off pentode. Because of the remote cut-off, it is of little use in audio. Datasheet: http://www.mif.pg.gda.pl/homepages/f.../084/7/7A7.pdf
7B5 is a loctal socket equivalent of the 6K6 and 41 tubes, so it's a power pentode (unlike the 6V6 which is a beam power tube). It is intended for audio output stages, datasheet here:
http://www.mif.pg.gda.pl/homepages/f.../127/7/7B5.pdf
7A8 is a loctal socket octode converter, octodes in general are very rare, and intended as mixer circuits in radio receivers. Although it is possible to connect it as a pentode or triode, such use for audio would probably be either as an experiment, an attempt to be different as a means unto itself, or as an act of desperation when it's the only tube left
Datasheet: http://www.mif.pg.gda.pl/homepages/f.../127/7/7A8.pdf
7C6 has a high mu triode similar to type 75 along with two small signal diodes in the same envelope. The triode is suitable for grid leak bias operation and has a mu of about 100, making it similar to a section of a 12AX7 or a higher mu 6SL7. Datasheet: http://www.mif.pg.gda.pl/homepages/f.../084/7/7C6.pdf
Old 3rd March 2008, 07:57 PM   #3
Default Tube Virgin
Hello ilimzn
Thanks so much for the time you spent with this most comprehensive reply. Much appreciated Now I'd better get on the case and find something to do with these tubes.
bulgin
Old 3rd March 2008, 08:47 PM   #4
Default Tube Virgin
Well
I called myself a "Tube Virgin" but it's not quite that bad Here's some of my Leak things, set up for a "do" last weekend when my engineering society had an "open day" for the general public.
bulgin
Old 3rd March 2008, 08:58 PM   #5
Gordy is offline Gordy  United Kingdom
ilimzn, you deserve a big prize for such a comprehensive answer. I am sure that many people will appreciate your work.
Old 3rd March 2008, 09:04 PM   #6
diyAudio Moderator Emeritus
ray_moth's Avatar
Agreed 100%.
Old 3rd March 2008, 09:38 PM   #7
Default Tube Virgin
Hello guys
As the recipient of ilimzn's generosity of spirit and knowledge
I can only but agree that The MAN from Zagreb is an example to me and to all of us.
Although I have some general audio knowledge, tubes (or valves in South African-speak) are indeed virgin territory for me. Many years ago - about 45 to be exact - I did build a small valve amp while still at school. A steep learning curve awaits again...
bulgin
Old 4th March 2008, 01:09 AM   #8
Now, now, be fair. We made excellent use of the 'AL5 in the B- supply of "El Cheapo". The type works quite well in low current hybrid bridge rectified supplies. 18 mA. should be enough for a buffered line stage. Double up tubes for more current.
Eli D.
Old 4th March 2008, 01:24 AM   #9
Ilimzn,
Good work above. I have just replied to post by you on Triodes vs Pentodes. As said there, you are quite a formidable person! (Wish we could meet, only Zagreb is rather too distant for my budget. )
Old 4th March 2008, 01:34 AM   #10
tubelab.com's Avatar
ilimzn:
Thanks for the info. I had not seen the triode curves for the 6AK5 before since they are not on the data sheet that I have. I have a few zillion of these tubes and will be doing some more testing in the near future. Ditto the 6AM6.
I tend to agree here. I don't use tubes for bias rectifiers since I want to be sure that the B- is available before the B+ is. A 6AL5 is slower than a 5Y3, 5U4, and some 5AR4's. The second most useless audio tube has got to be the 2D21. Too bad that I have about 1000 of each!
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Horny valve virgin comes of age.. aquapiranha Full Range 55 16th November 2007 06:02 PM
Audio virgin! Lostcause Multi-Way 15 3rd August 2005 05:37 PM
audio virgin noobs Solid State 2 8th March 2004 08:06 AM
SOZ virgin needs help! Lenin Pass Labs 38 28th March 2002 07:12 AM
Page generated in 0.13410 seconds (83.46% PHP - 16.54% MySQL) with 11 queries
