diyAudio Sponsor
Old 3rd March 2008, 04:15 AM   #1
Default Chassis layout help
I'm looking to redo my 2A3 SET chassis. This time I'm thinking 2 separate enclosures for better isolation. I use 105 db horn drivers so low hum or buzz is critical.
Here's the layout.
Any suggestions? Thanks.
Old 3rd March 2008, 04:39 AM   #2
rdf is offline rdf  Canada
rdf's Avatar
Just thinking out loud...
Ears aren't microphones.
Old 3rd March 2008, 10:08 PM   #3
rdf, thanks for the input. Question, why not put all the power caps in one chassis?
Old 3rd March 2008, 10:57 PM   #4
rdf's Avatar
Depending on topology you might want to move both pairs. Placing them on chassis from the audio stages effectively adds 24" (?) of wire in each direction, B+ supply and ground return. That wire adds an order of magnitude or more of inductance and resistance to the cap and scotches two benefits of what appear to be nice oval oils. By keeping that loop tight you're also much less likely to run into high frequency oscillation issues, hum, etc. . The actual placement on the audio chassis was just an aesthetic guess, close is all that counts. If you prefer not to move either consider large, high quality local bypasses right at the audio circuit.
That drawing is the layout planned for an 813SE on my bench, the reason it was ready for suggestion.
Old 3rd March 2008, 11:52 PM   #5
I see your point. Yes, those are motor run oil caps.
Thanks.
Need help with chassis layout bluegti Chip Amps 2 21st December 2008 01:32 AM
Chassis layout? Psychobiker Tubes / Valves 0 12th March 2008 11:12 AM
Transformer chassis layout Richard Ellis Tubes / Valves 5 27th December 2007 01:54 PM
Chassis Layout & PS questions Valvomaniac Tubes / Valves 3 11th April 2007 07:46 AM
help with chassis layout jarthel Tubes / Valves 5 27th June 2006 04:41 PM
Page generated in 0.08068 seconds (70.02% PHP - 29.98% MySQL) with 11 queries
