| diyAudio Sponsor | ||
I finally got around to documenting this HV bench supply that I designed and built a while ago... Details, schematics, etc. are here: http://www.pmillett.com/HV_bench_supply.htm Pete |
#2 |
Dammit - something else I gotta build. Pete, you're the man ...again.
#3 |
Nice ps Pete. Very nice
I've been wanting to build one that a bit more powerful then my isco. Nick |
#5 |
Just as I had managed to get all components to Bruce Rozenblits PSU ....
On the other hand - a friend of mine has scrapped two HEAVY PSUs at his work and one is for me. However his job is 500km away.
/Magnus
#6 |
Splendid! About the only information you didn't give was its mass. Lots, I imagine.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#7 |
Newbie question: I'm considering building this, and my B+ transformer on-hand is good for 360V@160ma.
Can I use less pass tubes? I'm assuming that these are paralleled to allow for Pete's 500ma current requirement. I have a handful of Chinese 6L6GC's. If I can reduce the number of tubes to say 2 or 3, does anything else need tweaking? |
#8 |
That should work fine. I'm also going to build something along these lines, though probably more like a Heathkit IP-32 on steroids. Note that you'll need other supplies for the screens and for bias. The way the supplies are floated, they need to be separate windings.
#9 |
I'd love to see someone sell a PCB for one that tops out around 550V. My Heath is only good to 400V. This would Make a great DIY item as these are hard to find new.
#10 |
I got a commercial one that goes to 1000VDC @ 200MA. Measures volts, current and computes watts. It's got a digital display. Very kool but it kicks out the overload breaker or frys the voltage control pot (5K) randomly. When I get around to it I'll start with replaceing all the caps otherwise it's got too many sand state components for my meager brain. I'll have to get it fixed. I hope it's KVA rated. Like 500VDC at 400MA? That would be nice. It's a piece of medical equipment used in DNA testing or research. I have not been able to find a scheme.
| DDD mfg co High Voltage power supply? | firechief | Tubes / Valves | 3 | 10th March 2009 03:07 AM |
| high frequency high voltage power supply... | moray james | Planars & Exotics | 6 | 23rd July 2008 08:57 PM |
| Low Voltage High Power Supply | thndr | Power Supplies | 4 | 2nd February 2008 01:33 PM |
| high voltage power supply | leemajcool | Power Supplies | 3 | 5th August 2007 12:40 PM |
| Page generated in 0.10969 seconds (77.88% PHP - 22.12% MySQL) with 11 queries |
