| diyAudio Sponsor | ||
Here's another mod I'm working on: an all octal output section from an old radio. I'm converting for use as a guitar amp and wonder
1] anything look out of sorts? I'm thinking of losing the caps across the output xformer but what else? 2] can I just hook this puppy up with a volume control into my favorite preamp? Any other suggestions would be appreciated. Thanks in advance. |
#2 |
I would try it both with and without those capacitors at the primary of the OPT. More importantly, I would get rid of the feedback loops. For a guitar amp, these will make for a nastier clip behaviour that probably won't be desireable. I would also redesign the 6SN7 input stage as an LTP phase splitter/preamp. That'll certainly be an improvement, and, yes, it will work just fine with your preamp. That's what I'd do. |
#3 | |
Any links for design ideas to utilize the 6SN7 as a PS/Pre? I would assume it would be similar to using a 12AX7 or such, but the component values would be way off [?] I've sniffed around a bit but cant' find anything readily. |
#4 | |
This new LTP input stage should have active tail loading from a CCS made from cascoded BJTs. This can either run off its own negative rail, or you can elevate the grids of the 6SN7s a bit to make headroom for the CCS. |
| A question about the Radio-Shack (Tandy) 22-175b digital multimeter | gaetan8888 | Equipment & Tools | 1 | 1st December 2007 01:26 PM |
| 65 Motorola AM Car Radio Mechanical Question | 65blkbkgt | Car Audio | 7 | 18th June 2007 08:25 PM |
| Old radio quick question re PS | Simpleton | Tubes / Valves | 17 | 25th August 2006 04:25 PM |
| Stupid question about testing a Car Radio | soundNERD | Car Audio | 7 | 10th August 2005 05:44 PM |
| Page generated in 0.08497 seconds (72.86% PHP - 27.14% MySQL) with 11 queries |
