| diyAudio Sponsor | ||
I think finaly have wined up in the right place.
I need help from you guy whom knows more about those heatproducing amps than I do. I have this 23000 year old harman kardon 730 twin powered receiver which works excellent but the selector switch is gone and all the lights has died some 100 years ago! Well his got tyred and I can't get any selector switch as replacement to it nor those little bolls to lit up this oldie. Maybe somebody out there can help me out to get me some of those spares parts to it.. Anyway, I brought this Yaoin Chinese amp MC100B with a lot's of eggboiling heat producing things in it and I believe you guys call those tubes, valves or pipes whatever, hot are they like h.....l!. I think they are those KT 88 frying pans So, there is no base! It is, but nothing if I can compare whit the harman kardon. So I was wondering why? Does it help if I got an external preamp with loudness controll or an eqaulizer? Tell me what's going on because I don't hear that big bang as I'm used to get from the harman. So it's a big disspointment so far and nothing else. It's got to move this (look at the pic) x2 with a big bang which my harman does. |
#2 |
If you give some details on the parts you need, maybe someone could help find replacements. How many poles/throws for the selector switch? Posting a picture would help..
double complete rainbow all the way!! |
#3 |
As to the lack of bass, that is not too uncommon, but there are several possible causes. We'd need to look at the schematic, and know more about your system - like the speaker type, impedance and cables. It's likely to be lousy amp design.
Maybe someone on the board has modified the amp you have and can help. Have you tried searching?
#4 | |
I have tried to replace it during many years now and listen to lots junks, both with high end amps and receivers like Technics, Sony’s Akai’s Revox’s , Sharp’s Sansui’s and you name it they were all in my living room on try but no one comes near by. Is somebody out here who can tell me why? I’m an artist and photographer and very sensitive when it comes to sound. Now I brought this heater to amp (yaoin) weights six times as much as a Harman and there is no bass it’s like a sopranos comparing to the Harman. Anyway I have heard now that all frying pan owners have bad bass they just don’t want to say it or never heard a Harman. Its moves like hell my glasses shaking and dancing in the kitchen and just looked what I got it’s all JBL except some Piezzo on the high top. It’s low and high bass low and high mid, drivers in wooden horn. Okay back to the subject There is some things written on the switch but it’s deep inside in the case. It says PCB147F 94VI than bottom I think it’s just marking the position and finally some additional figures like 4551-7156 The selector had am, fm, aux1, aux2, phono1, phono2, But if any of you can supply me with volume, ballance and treble would be nice too. |
#5 | |
In one channel for example I got 2x15” bass split in to two, very low so called air suspension cabinet and high bass closed cabinet. Than, you got two drivers in a wooden horn low and high come in different size with 2 x 4” which overlap the two drivers and just for colouring the sound. On the top there is one JBL 075 and four Piezzo discount. Now the other side is almost the same but there is one 15” sitting in one big cube very low frequented faced to the flour to balance and colour the other sides air suspension cabinets sound. I got a very rich sound! That’s why it’s so difficult to find other amps because I’m loosing it. Yeah I tried to get answers everywhere on the MC100B and heard that many tube stuff even more expensive well known brand has problem with the bass they are intend to be floppy. This is happened with me when try to replace the Harman before with other brands but they were not tube. And finally, the cables? Well the 1 1/2” inch speaker cables are okay isn’t it? So as the pro cables between the CD , tuner and the reel to reel. |
#6 |
You can get very good bass with frying pans, particularly with sensitive speakers like you have...
You may have to change a few parts in your amplifier, as I did in mine, try to get the schema and ask the experts, thats what I did...
#7 | |
Finding an expert here in Sweden? Space age, nobody knows this things any longer here! Digital and throw away or change the card that's what they know here. If I were living in Russia or Hungary it would an expert in every doorway. that's bad it is here: |
#8 |
I am Portuguese living in Latvia, dont speak the language, nothing...
I buy everything on the internet, all my help is virtual, still I did several mods on my amplifier... http://www.melorib.com/diy.html |
#9 |
Have you tried a little switch-cleaner in the Harmon amp...? This could help the controls, But dont use too much (I prefer the older equipment best too!).....
I believe Tubetvr, who is a member here lives in Sweden, Maybe he can help you.... I have no personal experience of your new amp, but have heard those are low on bass, but dont know why sorry...
Das Beste Oder Nichts |
#10 | |
Yes it had been cleaned many times but it's just don't work any longer. I guess I have passed the cleaning limit just one time for many. :-) But if I got the parts I need I will fix it! Yes they are a little bit to thin with out power and it doesn't matter if the volume is low or high it seems that the amp not giving much power to the bass. Even if power overated by the manufcture should be working as the tranformators are big twice the size of the harman and it's a class A with 30/60 watt. It's weights 30 kilos! What is the secret of the Harman? |
| Yaoin MC 100 B | boboo | Solid State | 9 | 2nd March 2008 11:56 AM |
| Page generated in 0.12354 seconds (83.56% PHP - 16.44% MySQL) with 11 queries |
