Screen grid zeners; which?
Old 4th March 2008, 09:54 PM   #11
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally posted by Johan Potgieter
Simon,
Mind giving me a website for that triode-trick if there is one? (All I find under Bill Perkins are a politician and a saxophone player!)
You can find it Right Here. It's a steaming, stinking pile of audiophoolery.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 4th March 2008, 10:02 PM   #12
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
A typical snake oil (proportions, diodes, etc...)
The Devil is not so terrible as his math model is!
Old 4th March 2008, 10:03 PM   #13
Johan Potgieter is offline Johan Potgieter  South Africa
Ah, that lot! But I have that under Grimwood, not Perkins. Same thing?
Nevertheless thanks Miles.
Old 4th March 2008, 11:09 PM   #14
rdf is offline rdf  Canada
rdf's Avatar
Perkins recommended a string of cap-bypassed zeners from plate to screen to force a constant DC voltage between the two while maintaining an AC short.
Ears aren't microphones.
Old 4th March 2008, 11:22 PM   #15
mach1 is offline mach1  Australia
Banned
Johan,
I think this is what you were referring to:
http://www.t-linespeakers.org/tubes/triode-trick.html
Old 4th March 2008, 11:30 PM   #16
Banned
And then there is this:
Old 5th March 2008, 01:02 AM   #17
Originally posted by mach1
Johan,
Thanks, Mach1, that seems to be it.
...the advantage again appearing unclear. Not to belabour, but there seem to be certain guys who are constantly in fear of too much screen dissipation. When the data sheets show that Va=Vg2 is safe, and in fact give the g2-current, it can be easily seen that screen dissipation will be safe. With triode connection there is no "wasted energy" - it all goes to the anode.
Just for those new to this field of bewildering claims.
Old 5th March 2008, 01:21 PM   #18
Klimon is offline Klimon  Belgium
http://www.hawthorneaudio.com/forums...php?f=5&t=1327
Old 5th March 2008, 01:21 PM   #19
Confessing I don't know the second thing about electronics but this little (despised ) circuit clearly sounds better to me than simple resistor: better bass-attack and better pace overall. The amp is an el84 set; I now actually use only three zeners + a single 1000F cap this sounds smoother than the published circuit. These are just my findings.
Simon
Old 5th March 2008, 11:16 PM   #20
Hi Simon,
Perhaps it was not said; I didn't check (I see that it is quite acceptable in some circles to say one is not feeling so well!). But yes, you have perhaps gathered that a screen grid can draw a quite varying current. Thus, using any resistor dropping more than a few millivolt (higher than the typical 100 ohm), will cause extra distortion. Triode operated pentodes are only that if the screen exactly follows the anode, otherwise an extra factor is introduced. Such a "close-coupled" condition is achieved by using zeners (or whacking big capacitors).
Thanks for that reference. I am greatly temted to be naughty and reply with some of Eddie's own advice: Do not listen to all the guru's! No further comment.
Screen grid zeners; which?Hide this!Advertise here!
Screen grid resistors stoo Tubes / Valves 66 20th October 2015 07:35 PM
Grid - Screen Alignment (X-Rays) kenpeter Tubes / Valves 126 25th January 2012 01:25 PM
Screen grid driver for PL519? Fuling Tubes / Valves 6 24th November 2010 02:36 AM
6V6 SE and Screen Grid Voltage zxx123 Tubes / Valves 5 2nd February 2005 05:36 PM
screen grid decoupling cap question.... Morse Tubes / Valves 10 21st April 2003 12:29 AM
Copyright ©1999-2017 diyAudio
