| diyAudio Sponsor | ||
I put the instructions for making the 6BG6GA adapters away for safe keeping and now I cannot remember where
Anyone got a spare copy? |
#2 |
#3 |
That doesn't help ....no info
#4 |
Use the forum to PM me your email addy, I will scan my copy for you.
- Fred - |
#5 |
Thanks Fred
#6 |
I would like to wire in 6BG6GA's permanent in a stereo 70 I have.
Would it be permissible to use the pin #6 a a tie point to wire in the high voltage plate wire? |
#7 |
It should be. Usually, if a pin shouldn't be used, the base chart will say something like "IC" (internal connection) rather than "NC" (no connection). Now, since that pin is right next to the grid pin, you should take some precaution to avoid arcs.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 | |
#9 |
Depends. If you make sure that the pins are bent back away from one another, avoid points, and insulate with heat shrink (all easy measures), you'll be fine. This isn't kilovolts, it's about 500V. If you have any qualms, then use a terminal strip.
#10 | |
I'd say it is a bit more than 500V. The plate will have signal AC on it. So B+ plus positive plate swing. IIRC my back-ov-the-envelope calculations for a St.70 that is around 350V or so at full power. 800 V is a peak, and to that we'd add bias and the negative g1 voltage applied by signal. Probably another 100V or so...so we are indeed near 1 kV...heh-heh-heh cheers, Douglas
the Tnuctipun will return |
| Simple SE and 6BG6GA's | whitelabrat | Tubelab | 18 | 25th October 2011 04:46 PM |
| F5 Build Instructions | 1108 | Pass Labs | 4 | 12th May 2009 10:58 PM |
| Kyocera DA-310cx needed tray belt and instructions | Bhu108 | Digital Source | 0 | 10th May 2009 09:47 PM |
| KT66/6L6GC/5781 6BG6GA replacements. | gregaz | Swap Meet | 0 | 16th February 2008 02:54 PM |
| Got my 6BG6GA's last night | Original Burnedfingers | Tubes / Valves | 10 | 5th November 2006 11:42 PM |
| Page generated in 0.09316 seconds (76.05% PHP - 23.95% MySQL) with 11 queries |
