| diyAudio Sponsor | ||
Magneto the Gravity Man
I have a few 6336s.
Could I use one as a rectifier by strapping the grids to the anodes and commoning the cathodes ? If so, what would limit the current? The grid ? What current could I expect to pass ? Andy |
#2 |
Not ideal situation....
But if you do try it, Tie G1 to the cathode or it will self destruct by excess current/volts through G1! connecting G1 to cathode will make it electrically 'invisible' to the valve.... Has the 6336 got separate cathodes per section...?--Not familiar with it.... As to current, volts drop etc, who knows! BTW, where in Wales are you...? I'm in Swansea....
Das Beste Oder Nichts |
#3 |
You can make a mediocre rectifier that way, yes. It will take 30 watts of heater power, timer circuitry to prevent application of power until the heaters are completely warm, and will give you a max output current of 300mA or so per section. The drop will be higher than a GZ34; at 100mA, the drop will be about double. The max voltage will be considerably lower.
Seems a waste of a perfectly good regulator tube. A cheap GZ34 will do a much better job.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
OK, thanks guys.
I will not bother then. ..................Closed.............. |
#5 |
Or you can try these:
http://cgi.ebay.com/SVETLANA-5C8S-17...QQcmdZViewItem The sockets are a bit hard to find, but they're easy enough to make. John |
#6 | |
Wasn't WE who used a 845 as a rectifier for another 845 ? Yves. |
#7 |
pls dont try 6336 as rectifier,,,,6336 is a nice tube for output stage ..SE ..PP ,,or parafeed
#8 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#9 |
Hello Tubelab,
Just curious: could you post or pm the schematic of your 6336A -SE? Could not find it on your site. Best, Arjen. |
#10 |
My 6336 SE Parafeed ampl ...15W/ch,, 20H load choke, 2mf coupling cap, with marvellous sound
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| 6CJ3 rectifier or 6D22S rectifier | 56oval | Tubes / Valves | 10 | 19th April 2007 09:48 AM |
| 6336-SE modification | av-trouvaille | Tubes / Valves | 26 | 30th November 2006 08:06 AM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.09931 seconds (79.38% PHP - 20.62% MySQL) with 11 queries |
