#11 |
another tube to throw into the conversation is the newer octal EL 509. Single ended use should get something close to 20w. I seem to remember a seeing a schematic on the forum for such an amp with screen drive and using a 6BM8 as an input and driver, I think.
#12 | |
#13 | |
What I heard from the LAMM + Von Schweikert DB99 was astounding transparency, and palpability. Somewhat spooky really, but it has great tight bass, and high frequency extension to boot. I was moved while listening to the CD "The Fountains of Bellagio, volume 3" |
#14 | |
I got a box of 10 for $80 on ebay a couple years ago from a guy named Anthony Welsch. There was 1 that was defective, but the rest were good and unused. Now they go for around $15 US each, which is more expensive than before, but way cheaper than a 300B.
#15 | |
In order to avoid problems with the 6C33C follow some simple rules: Switch on heater only and let it stay for that up to 2 hours Switch on anode voltage and let the anode current go up to ~200mA and let is stay there for 2 hours. Re adjust bias after about 10 hours operation. Always switch on the heater at least 1 minute before anode voltage. Following these rules you will have reliable tubes withe very long life, I have now used the same set of tubes in my own OTL amp for about 7 years without failure or loss of performance. Regards Hans |
#16 |
Rather than go for more watts, how about using the watts you have at higher efficiency?
Get a pair of Goodmans or Tannoy 12" full rangers or bass units and build yourself some great sounding, high efficiency speakers. 8 Watts is quite a lot really. |
| * 35 watt * 300B SE = super 300B + Class A2 | rick57 | Tubes / Valves | 4 | 13th July 2005 04:18 PM |
| "....This is not a Dream.... | KBK | The Lounge | 20 | 27th February 2005 10:19 PM |
| DREAM-77 problems | muhy3 | Multi-Way | 0 | 2nd November 2004 01:15 AM |
| X-SOZ... just a dream for now | Giacomo Pagani | Pass Labs | 39 | 12th December 2002 05:06 PM |
| Dream Kit? | realtree71 | Multi-Way | 8 | 20th February 2002 06:30 AM |
