| diyAudio Sponsor | ||
I’ve been reading about the benefits of using a grid choke in place of the grid leak resistor on the power tube (2A3 or 300B). Some place I read that’s not a good idea if the input/driver is a pentode?
Has anyone used a grid choke on the power tube when the input driver is a pentode? Is this a bad idea with a pentode (wired as a pentode). Here is what I have: The pentode is an EF37A (6j7) RL = 60K Ra = 2.5M Coupling cap = .47uf Grid leak resistor (2A3) = 470K |
#2 | ||
#3 |
Your 60K load on the pentode is the source impedance. A 150H choke is 18K at 20 Hz... so you're down 12 dB, and -3 dB at 60 Hz... what you need is a lower impedance driver. If your driver was a 12BY7 you MIGHT stand a chance...
#4 |
Tom / Niles,
Thanks for the replys The grid choke I had in mind was a MQ 16NI 4800H or a MQ 16M6 1000H XL=6.28*20K(hz)*4800=602K or XL=6.28*20K(hz)*1000=125K Do either on of these work with my EF37A? Then the real question: is it worth $100-$150 |
| Pentode grid question... | CSlee | Tubes / Valves | 10 | 28th March 2009 07:02 PM |
| Grid choke as I/V? | dsavitsk | Tubes / Valves | 1 | 8th April 2008 06:44 PM |
| pentode with grid AND cathode tied to gnd? | xdissent | Tubes / Valves | 5 | 28th December 2007 01:18 PM |
| Pentode current sink - how to connect the control grid? | ray_moth | Tubes / Valves | 4 | 20th December 2004 02:26 AM |
| Setting Pentode Screen Grid Voltage | dshortt9 | Tubes / Valves | 1 | 19th January 2003 11:22 PM |
| Page generated in 0.08362 seconds (75.46% PHP - 24.54% MySQL) with 10 queries |
