| diyAudio Sponsor | ||
Here is a schematic of a converted amp I'm working on. I 'broke' the circuit and inserted another gain stage from within the chassis which is the second half of the 12ax7 going from left to right. The original circuit is above the new gain stage. The original circuit fed a reverb tank at this point. I inserted the gain stage as shown from the return from the reverb tank. I inserted the 1M pot for a volume control as shown.
I have a few questions about this circuit: 1] first off, is there anything I need to do in the 'duh' mode as far as the hack of the new gain stage? Any components way off value/unnecessary? 2] Can I just add another 1M between the .02 interstage and the 1K resistor prior to the second stage? as another gain control? 3] Can I drop another pot somewhere just prior to the inverter to act as a master volume? 4] as I crank the one gain pot, the next stage distorts [good] but the highs begin to drop off. In fact, overall the frequency response seems to tend toward the lows. Fixes or change in value of existing circuit to remedy? 5] Tone control ideas? BTW this little circuit worked great as a clean amp prior to my mod, and now with the extra gain stage the amp cranks. I think I'm in love.. |
#2 |
Schematic?
#3 |
Let's try this again...ooh not much you can do w/ only 100k attachment...hope everyone can see this!
#4 |
Need to fix your schematic to reflect the circuit you actually installed, what you've drawn can't work. That added stage needs a source of B+, a grid bias resistor, and a separate path for cathode current to ground. (350 ohm resistor is also too small for use with 12AX7 typically) I assume of course that what you added and what you have drawn are not one and the same.
www.kta-hifi.net |
#5 |
The plate resistors on the last 12AX7 should go before the coupling caps, not after.
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz |
#6 |
There should be a 100k resistor to +275 at the inverter plate. Sorry!
#7 |
Left out a couple of parts. My eves must have been crossed when I posted this: drawing these things isn't as easy at it looks....
#8 |
Attachment didnt' workie.
#9 |
I'm assuming you neglected to show the grid bias resistor on the second 12AX7A stage, something on the order of 1M to ground is in order if it's not there. Otherwise this schematic makes a bit more sense..
www.kta-hifi.net |
#10 |
Ah...another error creeps into the works. There is in fact a 47k resistor in that spot.
| CD723 Hack, did someone download it? | Andypairo | Digital Source | 23 | 20th April 2010 10:38 PM |
| Preamp suggestions - Help a hack have some fun | tubesmuggler | Tubes / Valves | 9 | 13th December 2007 11:29 PM |
| K7200 0-30v 0-10a Hack:) | gev | Power Supplies | 0 | 14th June 2006 10:57 AM |
| Page generated in 0.09789 seconds (77.69% PHP - 22.31% MySQL) with 11 queries |
