diyAudio Sponsor
Old 26th February 2008, 11:49 PM   #11
m6tt is offline m6tt  United States
I hope it wasn't a working organ once! Keep the spring reverb, if it's a gibbs part, it's worth it...probably 8ohm input to ?k (high impedance) output. I hope you wrote down the circuit values for that reverb driver, Hammond & co. *invented* the spring reverb.
Old 29th February 2008, 06:32 PM   #12
Default latest version
Latest version of the schematic.
Old 13th March 2008, 09:35 PM   #13
Latest version reflects many changes including dumping a bunch of bypass caps, feedback circuit, guitar-style input voltage divider, etc. One thing that is missing from this schematic is my trial replacing the second volume control with a bandaxel [sp?] bass/treble control. Also not shown is the fact that I added some little niceties like a power switch, lamp, standby switch and fuse.
The gain is great, too great in fact, and I'm thinking voltage divider right after first [now only] volume control?
BTW this little amp started out pretty tame but has grown into a little screamer!
CD723 Hack, did someone download it? Andypairo Digital Source 23 20th April 2010 10:38 PM
Preamp suggestions - Help a hack have some fun tubesmuggler Tubes / Valves 9 13th December 2007 11:29 PM
K7200 0-30v 0-10a Hack:) gev Power Supplies 0 14th June 2006 10:57 AM
Page generated in 0.07053 seconds (69.48% PHP - 30.52% MySQL) with 11 queries
