diyAudio Sponsor
Old 11th March 2008, 07:57 PM   #21
pchw is offline pchw  United States
What option (or method) to use to get those nice sine wave like curve in psud2?
Thanks!!
- Fred -
Old 11th March 2008, 08:36 PM   #22
Plug in all the states as described in the thread :
Then - left click and drag a LOOOOOOONG!!! rectangular box around the END of the long sweeping curve (when the voltage has stabilized).
Repeatedly do this until you can see the ripple, then just select a smaller portion to to get the 'nice' wave
Old 12th March 2008, 12:53 AM   #23
Thanks for the help, folks. I still can't duplicate the results shown above. I've inputted all the data shown including the stepped load. Simulation quits with an error message:
"A current sink has pulled the voltage below zero for more than 5 mains cycles, at a time 1.907917S"
Old 12th March 2008, 07:57 AM   #24
I used to get that. It's due to immediate load. Can you screenshot your PSUD?
L
Old 13th March 2008, 03:11 PM   #25
as an aside....no load voltage today was 410VDC w/ <8mV ripple on what will be the 6V6 anode line!! I'd hazard a guess (the resistor isn't in there yet, hence I can't measure properly) that the 12SN7 line will be almost pure DC
3d amp modelling (for solidworks) andrew_whitham Tubes / Valves 43 9th November 2011 07:58 PM
modelling PSU for Aikido cbutterworth Tubes / Valves 16 1st December 2007 03:21 PM
Modelling of mosfets TroelsM Parts 11 26th July 2006 05:01 AM
Yet another online modelling app Vikash Multi-Way 5 29th August 2003 09:07 PM
Page generated in 0.07842 seconds (73.66% PHP - 26.34% MySQL) with 11 queries
