What size capacitor I use for a 2A3 or 300B cathode bypass?
Old 21st February 2008, 05:51 PM   #1
sgerus is offline sgerus  United States
Default What size capacitor I use for a 2A3 or 300B cathode bypass?
300B Cathode Bypass Capacitor Value / Options?
Simple question, Right?
Here is what Iíve seen:
1. 100uf seems to be the most popular
2. Seen values as low as 20-30uf for a 2A3
3. Some use 3 capacitors, one each on pin 1 and 4, and 1 on the hum pot. Iíve seen 3-50uf and 3-10ufÖ Sometimes with the caps on pin 1 and 4 bypassed with lower values.
4. Then some people bypass the main capacitor with 2 lower values:
100uf, then 1uf, then .001uf
5. And then thereís the Ultapath, which adds a capacitor from the B+ to the + side of the cathode bypass cap.
(This is what I used in my current amp)
So the choices are all over the map, 20-100uf with 1 to 5 capacitorsÖ What do you folks prefer?
Old 21st February 2008, 11:11 PM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
1. Because there's a Black Gate value that's 100uF
2. Because they're so big, like an Obligatto
3 & 4. Was discussed by Morgan Jones on the 3rd Edition
5. Because it's a Western Electric invention?
I prefer a "compromise" - Black Gate on the cathode
Old 22nd February 2008, 12:22 AM   #3
Miles Prower is online now Miles Prower  United States
Miles Prower's Avatar
Default Re: What size capacitor I use for a 2A3 or 300B cathode bypass?
Fixed bias. That way, I don't have to worry about it.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 22nd February 2008, 01:21 AM   #4
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
I agree wth fixed bias in theory, though my 300b amps are ultrapath (50uF). But, to determine the standard bypass cap, use
(Rp + rp) || Rk
and plug this into
C = 1/(2 * pi * F * R)
where the above is R, and F is your 3dB roll off frequency.
Old 22nd February 2008, 05:52 AM   #5
(Rp + rp) || Rk
and plug this into
Shouldn't that be:
Rk || rk where:
rk= (Rp + rp) / (1 + u)
www.dolphin-hsl.com
Old 22nd February 2008, 05:57 AM   #6
dsavitsk's Avatar
D'oh! My first day of law school, one of my professors was referring to some law and pulled out a copy of the statute to look at it to make sure he had it correct, even though he had written it in the first place. The lesson, of course, was not to assume you remember something but to look it up to be sure you are correct.
Old 22nd February 2008, 01:33 PM   #7
Miles, Could you explain why you donít have to worry about it with fixed bias?
Letís look at the formula.
Given:
RL=3000 (OPT)
Ra=700 (JJ300B)
U=3.85 (JJ300B)
Cathode bypass Res=1K
Rk=(3000+700)/(3.85+1)=762R
rík=1K//762R=432R
At 20K hz 1/(6.28*20*432)=18uf
At 10K hz 1/(6.28*10*432)=37uf
At 5K hz 1/(6.28*5*432)=74uf
At 4K hz 1/(6.28*4*432)=92uf
At 1K hz 1/(6.28*1*432)=368uf
Based on this, 18uf is good for 20hz, which is also the rating of most OPTís
Using 100uf is good for <4hz, which seems like overkill?
My current amp is set up with a 100uF oil for the cathode bypass and a 20uf for the ultrapathÖ.. Think Iíll do some testing over the weekend!
Old 22nd February 2008, 04:33 PM   #8
kevinkr's Avatar
Given:
RL=3000 (OPT)
Ra=700 (JJ300B)
U=3.85 (JJ300B)
rík=1K//762R=432R
Because with fixed bias the cathode (or filament in the case of a dht) is grounded, there is no cathode resistor and hence no need to bypass it with a cap. Negative bias voltage is applied to the grid.
Incidentally when I go for cathode bias I usually use 100uF with a 20uF cap for hum cancelling alla Western Electric, but like Miles I much prefer fixed bias for this application.
By the way 100uF is not overkill, it really depends a lot on the primary inductance of the transformer, the L, R, C present in the output circuit conspire to create a series resonant circuit which at the secondary actually appears to look like a low to moderate Q parallel resonant circuit which at resonance can produce a significant boost in low frequency response - depending on where the boost occurs it can result in flabby, overblown bass, or worse can pump a significant amount of subsonic energy into your speakers if present at the input of the amplifier. (record warps, etc.)
The above is just another reason why I prefer fixed bias. (Transparency, ease of tweaking op point for "voicing" the amplifier, etc.)
By the way you meant Hz not kHz right?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 25th February 2008, 04:15 PM   #9
Hereís a follow up on some listening tests with different value cathode bypass caps for the 2A3:
I tested 3 values, from one extreme to another:
1. 200uf Mallory electrolytic bypassed with a with a 2.2uf Solen
2. 100uf Oil
3. 18uf E-Speaker Audio Cap
My test was rather crudeÖ. Turn off the amp, jumper in the new cap, turn the amp back on and listen, then repeat with other caps.
My preference for right now after only 2 hours of listening is that the high quality 18uf cap sounds best. Of all the pentode driven (WE91 type) amp schematics I found, 16uf was the lowest value shown, with the average being 63uf.
In interesting side note: An ďunofficialĒ schematic of the Wavelength Cardinal shows a 39uf Solen used for the 300B bypass.
Now I need to wire in a switch for the bypass capís and so some ďBlindĒ listening tests.
I wonder if my crude test proved that to some point, quality is more important than a higher value uf?
Old 25th February 2008, 04:44 PM   #10
kevinkr's Avatar
Yes cap quality is critical here which is why I use fixed bias whenever feasible, and you may also be getting some "pleasant sounding" low bass boost with the 18uF that would be subsonic with larger values of bypass cap. Can you measure the frequency response of your amplifier to see?
What size capacitor I use for a 2A3 or 300B cathode bypass?Hide this!Advertise here!
Choosing A Cathode bypass capacitor alexmoose Tubes / Valves 19 7th September 2014 11:08 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
Question about cathode bypass capacitor: rockgardenlove Tubes / Valves 4 24th October 2008 08:34 AM
Question about cathode bypass capacitor argo Tubes / Valves 15 20th February 2005 10:26 PM
Does a cathode bypass capacitor reduce hum? ray_moth Tubes / Valves 23 21st August 2004 01:38 AM
Copyright ©1999-2017 diyAudio
