| diyAudio Sponsor | ||
#11 | ||
Magneto the Gravity Man
Thanks for the info guys !!! Andy |
#12 |
I bought two of the 100K volume control as shown in kevinr's message. I tested them by feeding it with signal generator and see the output with an oscilloscope.
I was surprised that there were very high sharp spikes at the leading and falling edgies of the square wave at the output especially at low volume positions, lower the worse. I broke one in pieces to find out why that happens. May be it was caused by my test set up or may be it was caused by internal stray capacitance within the switch. I have better success in building stepped volume control with resistors in series that I could see very favourable square wave response. I just hope someone would test it and confirm my finding. Johnny |
#13 | |
I also have one of those attenuators as pictured in kvk's and Kevin's posting. I tried to measure this thing in order to find out how it is supposed to be wired up, but no real success yet.
I also coincidentally found the pic attached (courtesy of triode dick's page)... so can anyone provide a simple schematic or description how it should be wired up? thank you! |
#14 |
Hi Stixx
I edited your picture in paint. I think it is right, but it is easy to test. Put a DVM across the (marked) input and ground: this meter should read the pot's value (10k, 50k, 100k, whatever) in any position of the wiper. A second DVM is connected between the output and ground. This one should read low ohmic values for the low level settings, and increased values for the higher level settings. Viel spass mit ausprobieren, und lassen Sie bitte wissen oder es funktionirt. (Good luck finding out, and please let us now if it worked) Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
#15 | |
Thanks alot, I will try out... It is going to sit in my aikido headphone amplifier that I'm about to finish (breadboard version first). I'll post my impressions... groet (my boss is dutch but I'm hearing only the bad words in nederlands from him...;-) |
#16 |
Help some guys with funny hair bang two rocks together really hard. http://athome.web.cern.ch/athome/LHCathome/whatis.html |
#17 | |
That rocks. Thanx for the post. |
#18 |
I compared the information with my stepped attenuator and found that two pairs of pins are connected as shown in OzMikeH's link.
When I measure across input and ground I am having 51K (both channels very exact), whereas across output and ground I am having ~0 - 36K... So everything looks fine to me! Thanks again Erik (and all the others...)! |
#19 |
Beautiful workmanship there Stixx
#20 |
I bought a rottary switch with 24 steps like the one from from upper pics
now I have to get a resistors can somebody recommend a place to purchase online good resistors I need 20 K or 10 K attenuator anybody tried the attenuator resistor set from thlaudio http://thlaudio.com/VishayDaleRmnE.htm |
| how is the quality of a chip-based volume control VS normal stepped attenuator? | jarthel | Parts | 4 | 16th July 2007 03:40 PM |
| PLLXO with stepped volume control? | Dartagnan | Multi-Way | 8 | 6th October 2004 05:17 PM |
| Noble/Alps stepped volume control | gjo | Parts | 0 | 11th March 2004 10:15 AM |
| Volume Control via logrithmic stepped attenuator | PaulHilgeman | Solid State | 4 | 6th February 2003 12:51 PM |
| Gainclome Volume Control using Log Stepped Attenuator | PaulHilgeman | Parts | 10 | 5th February 2003 09:40 PM |
| Page generated in 0.14282 seconds (80.12% PHP - 19.88% MySQL) with 11 queries |
