Printed circuit board designing? - Page 2 - diyAudio
Old 23rd March 2008, 12:36 AM   #11
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
That's actually not my amplifier, I just used the picture to show what I was talking about regarding mounting the capacitors on the opposite side of the board from the tubes.
Usually if using DC heaters, I'll run the lines on be board, because the rectifiers, filter cap and regulator (if using one) is mounted on the board. Even though it's DC, it's best to avoid running the lines too close while parallel to signal lines. And also, if it's a double sided board run the heater V+ and it's ground return overlapped on opposite sides of the board.
If using AC heaters, I twist the transformer heater wires and solder them strait to the socket pins.
Old 23rd March 2008, 12:41 AM   #12
Same as I am (putting the AC heaters offboard).
Here's pictures so far
http://www.flickr.com/photos/psychob...7604051618142/
Mark Levinson ML38 Printed Circuit Board Sunsun22 Swap Meet 2 8th February 2006 05:22 AM
Printed Circuit Boards for DIY Audio dmfraser Parts 8 3rd August 2004 10:52 PM
Printed circuit board options? DanK Solid State 49 20th February 2003 11:35 AM
Printed Circuit Boards - 4 layer thylantyr Solid State 3 18th August 2002 12:28 AM
Printed Circuit Board SUPPLY SOURCES G-Daddy Parts 3 29th July 2002 02:59 AM
Copyright 1999-2017 diyAudio
