I need a negative supply rail--but how?
Old 18th February 2008, 09:58 AM   #1
wally.gribbles is offline wally.gribbles  New Zealand
Default I need a negative supply rail--but how?
Hiya!
OK, I have a pile of 6N1P tubes kicking around here, and want to use them to make a bunch of op-amps for a project. All is good, based the design on the Philbick K2-W(J) with the values of all the passive elements re-sized accordingly, so it should be fine. Except...
The K2-W (and most any op-amp, I guess) needs a -300 VDC supply as well as the +300 VDC one (usual B+) one. Question is, how do a make a *negative* supply? A schematic would be most appreciated
Many thanks in advance!
Old 18th February 2008, 10:29 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
300-0-300 trafo, full wave bridge. ground the CT.
You can use tubes.. say a 5U4 for the + rail, and a pair of dampers for the (-) rail. Or silicon.. whatever. Your choice
Old 18th February 2008, 02:35 PM   #3
Eli Duttman is offline Eli Duttman  United States
Dave Cigna kindly showed in an old thread of mine, that using a bridge and grounding the CT is (in fact) 2X FWCT rails wired in opposing polarities.
If symmetry between the 2 rails matters, all 4 diodes should be identical. 4X UF4007s, with each diode paralleled by a 10 nF./1500 WVDC ceramic snubber cap., will get the job done. A pair of 6BY5s, each having a separate, floating, heater supply is (IMO) the way to go, should vacuum rectification be a must.
Eli D.
Old 18th February 2008, 06:58 PM   #4
Thanks guys, and sorry about the typos in my original post (oops!).
I *think* I understand what you're telling me, with the 300-0-300 transformer being the main ingredient in the design. I'll sketch it up and try it out a little later today to see if I got it right.
Cheers!
Old 18th February 2008, 08:30 PM   #5
Is this correct? Ignoring the sizes of everything, of course...
Cheers!
Old 18th February 2008, 08:36 PM   #6
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Yep!
Jorge
I need a negative supply rail--but how?Hide this!Advertise here!
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 06:18 PM
Full negative rail voltag on my output?? aletheian Chip Amps 1 26th October 2005 05:38 AM
GC problem: voltage dropout on negative rail scone Chip Amps 6 14th January 2005 08:15 AM
Strange Power Problem, no negative rail? Adam M. Chip Amps 16 15th September 2004 02:27 AM
How to regulate a negative rail with TL431? JoeBob Solid State 13 4th September 2004 12:56 PM
Copyright ©1999-2017 diyAudio
