| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Some say the 6V6, as per the Boozhounds build (6SN7 driver) will yield only 3W, yet I hear 12-odd watts bandered about, or is this only the GTA?
L |
#2 |
12 watts would be in push pull, ~ 3 watts in se and ~5 or so watts se with separate screen supply or ul.
The path to freedom begins with forgiveness. |
#3 |
triode SE will probably be around 3 watts.
ultra-linear SE will probably be around 4 watts. pentode SE will probably be around 5 watts. triode PP will probably be around 6 watts. ultra-linear PP will probably be around 12 watts. pentode PP will probably be around 15 watts. also depends on things like bias point, OPT primary impedance, etc. etc. |
#4 |
Cheers, upon further digesting the data sheet, it seems with 315V plate, triode strapped, it'll yield about 5.5W, given an 8k5 load. I'm taking it this can be made of a 5k OPT, and 3.5k resistor in series - surely the valve would 'see' 8k5?
L |
#5 |
Dont put the 3.5K resistor in series with the transformer. Yes, the tube will see something like 8.5K, but thats not the point. The 3.5K resistor is going to drop over 100 volts due to plate current and completely change the operating point. It will also dissipate about 40% of whatever ac output ower is produced, so considering power reduction due to 5k ac load line vs 8.5K, different operating point, and 40% loss in the resistor, you might only get 1 or 2 watts out. (guesstimate, precise numbers would need to be calculated)
You would be better off just using the 5K transformer. Best of all of course is the 8.5K transformer.
Robert McLean |
#6 |
A 5K transformer will work nicely at a different operating point, say about 250V / 50 mA...
#7 |
AFAIK, thats what the boozhound is calculated at - 250V.
Any recommendations on OPTs? Budget of appx $150. I've heard Frag Jan Zuerst's are quite good,? L |
#8 |
A single 6v6 in triode 1.5 Watts maximum. No way you can get 3 Watts. Try el84, a little more power for less distortion. Anyway this is what simSE says. Simulation tube program by Broskie.
#9 |
At what voltage tho?
L |
#10 |
I recently built a 6V6GT Single Ended amp that sounds very good. I have compared it to other single ended amps of known wattage and it has to have about 5 watts output. The guys on this forum helped me tweek the curcuit and it sounds great with absolutely no hum. I would highly recommend it. The output transformers are very inexpensive (Edcors). The schematic is below.
| Thread Tools | |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 11:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 07:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 06:17 AM |
| I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output | iklari14 | Digital Source | 30 | 18th July 2003 01:57 PM |
| Page generated in 0.19829798 seconds (72.78% PHP - 27.22% MySQL) with 11 queries |
