diyAudio Sponsor
Old 28th March 2008, 02:15 PM   #11
Lo and behold!!That's what I was originally building until I found the Boozhound Labs one which utilises a (sonically) far superior 12SN7
Old 28th March 2008, 04:49 PM   #12
Ty_Bower's Avatar
Originally posted by Tom Bavis
A 5K transformer will work nicely at a different operating point, say about 250V / 50 mA...
Is that a general rule of thumb? If the OPT offers a lower impedance load than you want, lower the voltage and raise the current? Does it work for push-pull as well? I guess I should be able to deduce the answer for myself by drawing load lines, but...
I ask because I have a set of 6.6K OPT (Hammond 1620) which I'm using with 6BQ5 tubes. My B+ is rather high (nearly 385V, K to A), so I run them at a lower current to keep the overall dissipation within limits. But, at low frequencies (20~50 Hz) they distort at relatively low power levels (3~4 watts out). I suspect it's probably just a limitation of these inexpensive OPTs, but if I thought they would perform better at a lower voltage & higher current, it might be worth the trouble to try.
Old 28th March 2008, 05:11 PM   #13
mine *should* run 250V...with 5k OPT.
Will let you know!
Old 28th March 2008, 11:45 PM   #14
I think you'll like the 6V6 triode strapped SE sound. When you get it up and running, you can also play around with popping in other tubes, like 6L6, or even 6550.
Yes, they'll run at a low operating point, but sometimes the sound can be surprising. I really liked 6550s running this way.
Old 29th March 2008, 12:07 AM   #15
nafanja is offline nafanja  Ukraine
Default about 6V6
If You stay the pair 6V6 in Paralel - but transformer with 100ma(Io) it's will be better for damping factor.You will get may be 0.5 Ohm for 4 Ohm output.
If You stay ecc81 or analog - it's will be better too.
Better for puls rate.
If You hear it - give me know.
Shippment: $:Europe: 1,2 x (16+2,45 x Weight(kg))
N. Amerika & Asia: 1,2 x (10 +4,9 x Weight(kg))
Old 29th March 2008, 04:23 AM   #16
As soon as she's built properly!! (about 3 wwwkes, given college etc)
L
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 01:57 PM
Page generated in 0.08300 seconds (76.42% PHP - 23.58% MySQL) with 11 queries
