diyAudio Sponsor
Old 17th February 2008, 04:06 PM   #21
Caio Basstard, You are quite welcome for the link. I found that a while ago and use it at work. I agree that it's very helpful. The main website has a lot of other useful info about electronics, computer hardware and even a section about old video game systems.
Pace,
Dave
Old 18th February 2008, 03:21 AM   #22
eyoung is offline eyoung  Scotland
eyoung's Avatar
Johnathan,
Where you use the wire determines the kind (stranded or solid)
of wire. DC or AC , I do not claim to be an expert, so someone correct me if i get this wrong. There is something called skin effect,
It is why speaker cable is many stranded as opposed to large solid core . I have a Hi -Fi side and a Lo-Fi side. My Hi-Fi side is all
transistor, but my lo-fi side is mostly tube(guitar amp) so i work with old guitar amps with B+ voltage from 350-600VDC and my hi-fi amps at 35-70VDC. My favorite guitar amp is a Groove Tube Studio PreAmp(has an output section with either 2 6V6 or EL34)
with a bunch of 7025 front end tubes and some solid state for the recording out speaker emulator. so I guess I am as confused as you are. From what I can tell from digging through a bunch of amps is solid conductor wire is used mainly in inductors, Transformers and high amperage busses. If you want to look critically at most amplifiers copper trace on a circuitboard could be considered solid conductor. Lots to think about.
So stop thinking and start building and use different wire in different places and see how it sounds..
Regards, Elwood
"when you open your mind to the imposible, soon you will find the truth...."
newbie, difference in hook up wire gauges? Joshua_j Parts 12 5th April 2009 08:03 PM
Analog Voltage Gauges ak_47_boy Parts 0 22nd June 2007 05:01 AM
Wiring LED warning lights on automotive gauges drfrink24 Parts 2 7th March 2006 10:28 PM
Where to Find Needle Gauges? PaulHilgeman Parts 21 18th October 2003 02:53 AM
Page generated in 0.06199 seconds (72.05% PHP - 27.95% MySQL) with 11 queries
