Help with common-cathode circuit.
Alright, I've got a 6922 tube that has to run off 150V (I already have the psu for it since I used it before in another configuration). Since it has a mu of 33 I'd like to get the highest gain possible, which I gather will be 33. I can't find a datasheet on the 6922 so I don't know it's plate resistance or any other specs and I forget what they are. I gather I'd have to bypass the cathode resistor with a cap to attain my desired voltage gain. I just don't know what values of the cathode resistor and plate load resistor would be optimal for a 150V operating voltage. Any help would be apreciated. By the way the load it will be hocked up to will be a cathode-follower if that makes a difference. Thanks alot again for any help I get. I'd be using a single half of a tube, no balanced operation here. Or would I need a ccs to attain the gain I want?
Frank is correct about the CCS, but I do wonder why you want to get ALL the gain you can? Any of those configurations to maximize gain will compromise distortion and bandwidth. If you need more gain, why not use a higher gain tube and run it in a lower distortion, higher bandwidth mode? Or use a cascode topology?
Re: 6922
fdegrove said:
A CCS will get you close to the max amplification factor as well, you'll need about 15mA.
Looking at it on the CAD, the only place I can actually find a mu of 33 is when the grid is zero, and the current is up around 15mA with Vak of about 50V. In most of the places where you will actually operate it, it's more like 27 - 29, and the Rp is about 3 - 4k. So even with a CCS, you're not going to get a gain of 33 from it.
datasheets galore
Others have said that this tube is unreliable at full disipation but since you will be using only one section this will help.
In my experiance using a 6DJ8 at some 80% disipation (both sections working) did cause a degradation on the tube, what went wrong I can't say.
I have been using 6922 at around 1/2 disipation with no problems.
IME, a cascode can easily be made to have no particular sound, i.e., output indistinguishable by ear from the input. Joe Curcio has done some excellent cascode-based designs; his power amp driver design, a cascode diff-amp, is particularly good. My own phono preamp uses a FET-tube cascode; quite linear and very low noise.
My experience with cascodes has been less than positive. Output indistinguishable by ear from input? I wish. Anything that uses caps, resistors, active components is immediately distinguishable. Or wire :) To my ears the cascode has much inferior sound compared to resistor, choke or transformer loading. The entire bias arrangement around the upper tube is also very difficult to get to sound well. Exaggerated dynamics, unnatural timbre. Seems quite successful in commercial gear so tastes obviously differ.
peter
The reason I'd like that much gain is because I've been using a 6922 as the voltage gain stage in my poweramp with a gain of about 8 and I'd like to up that gain so that I can remove the preamp (but keep the same tube in the circuit). I'd rather avoid chokes since they take up alot of room and I've got space problems already with this amp so I guess a CCS would be the best bet?
diyAudio Senior Member
Joined 2002
6922
Keep in mind what Brett has said though.
Pushing for gain is also pushing distortion levels, moreover take a look at the next stages, you may run it into clipping too.
I know, physics can be ruthless...;)
Joined 2002
CASCODE.
Hmmm...how can a circuit exaggerate dynamics?
I can see a few circuits that could compress dynamics, but...exaggerate them?
That a cascode circuit could alter timbre...yes, pretty much the same way penthode circuits could alter timbre, I suppose.
I feel this is a matter of taste and tonal balance, some people may like a bit of odd order distortion...
Some circuits to discuss: the totem pole and the grounded grid circuit. ( As a reminder for my own reference)
Cheers,;)
Ex-Moderator
Joined 2003
UHF oscillation
E88CC/6922 was designed for use as a UHF front end in televisions. Given half a chance, the little perisher will oscillate at UHF, and you won't see that on any (affordable) oscilloscope. Don't even think of using it without grid-stoppers. Surface mount resistors on the socket pins are ideal, and allow you to minimise their value.
