diyAudio Sponsor
Old 12th February 2008, 01:40 PM   #1
krzanik is offline krzanik  United States
Question Is this curcuit ok?
I built an amplifier from the attached schematic (hopefully it attached ok) and it sounds great but has a lot of hum. I'm trying to determine whether the hum is inherent in the circuit (due to its design) or if the hum is a result of the way I built it. The hum increases as you turn up the volume so it seems like the input is picking up hum and amplifying it along with the input signal. I have done everything I can think of to try and eliminate the hum. The heater wires are all twisted, the inputs are shielded and the output transformers are perpendicular to the power transformer etc. I was thinking of rebuilding the amp in a larger chassis and it occurred to me that the hum may be a result of the design rather than the implementation. Any thoughts would be appreciated. Thank you.
Old 12th February 2008, 01:59 PM   #2
engels is offline engels  Israel
engels's Avatar
Default pot?
Is this supposed to be hi-fi?? Then 500K input is a little too much.
Try to tie 100K-50K resistors from 12AX7's pins 2 and 7 to ground, unsolder the 22K screen grid resistors from the tube socket and then connect your signal straignt to those pins. You may hear some radio that way but the question is whenever the hum goes away or not.
Old 12th February 2008, 02:37 PM   #3
Yes, the curcuit is supposed to be Hi-fi. I'll make the suggested mods this evening and see how it sounds. I assume if the hum is gone I need to replace the 500k pot with a 50 or 100 ohm pot, depending on which sounds better?
Old 12th February 2008, 03:03 PM   #4
Trout is offline Trout  United States
Trout's Avatar
1st,
the power supply, The 47UF cap in the first position is way high for a 5Y3, It should be closer to 20uf. The 500 ohm resistor is rather low, I have a 1K in that position, and really, that is as low as I would go. As it is you will most likely experience arcing in the rectifier tube especially as it ages.
What are you actually using for the PT?
I am using a 300-0-300 transformer and the same Edcor output transformer.
The listed power supply voltages shown in your schematic are very low by comparison to my amp.
The Cathode resistor on the 6V6 is also IMO to small of a value. On my amp 500ohm was very hot and I upped it to 680 ohm.
But that is based on my voltages.
I measure 23V at pin 8 of the 6V6GT which the JJ brand 6V6S seems to like.
The drawing lists the feedback resistor * as 1K?? That's is a lot of feedback!
I have a 22K in that position and have tested up to 68K.
On the input(Pin2) of the 12AX7, I have a 1.5K grid stopper, and I would not go over 5.6K.
The Hum issue is most likely a grounding problem, If you post a picture ( Big Guts Shot ) it should be fairly easy to de-bug.
I originally had a hum issue in mine, but a tiny bit of re-thinking on the ground scheme resulted in a sweet hum-less amp.
I squeezed this into a Hammond 6" X 10" X 2" chassis, It was a tight fit, but not awful. I use it in my garage and have an old Celeron 750/ IBM ThinkPad as the audio source.
BTW, that is a pretty loud amp with efficient speakers.
Trout
YMMV
Old 12th February 2008, 03:06 PM   #5
kmtang is offline kmtang  Canada
kmtang's Avatar
To kill the hum, it is better to replace the 500 ohm resistor with a 5 to 10H choke which provides much better filtering for the B+ ripple.
Johnny
Old 12th February 2008, 03:14 PM   #6
Trout's Avatar
Johnny
Yep, I agree 110%, but he mentioned limited space.
I suspect there is another hum source, perhaps a grounding issue.
Old 12th February 2008, 04:23 PM   #7
Trout,
So you have built this amplifier? What value did you use on the volume pot?
Also you said:
"On the input(Pin2) of the 12AX7, I have a 1.5K grid stopper, and I would not go over 5.6K."
So I would replace the 22k resister (at pin 2) with a 1.5k resister?
I think I have incorporated the suggested changes in this revised schematic (except for the grid stopper, I'm not sure about how to do that). I have put a red box around the changes. I put in the type of power transformer as well. Please let me know if this looks ok. I've got the amp somewhat diss-assembled trying to work out this hum but I'll try to take a couple of pictures. Thank you.
Old 12th February 2008, 04:44 PM   #8
kevinkr's Avatar
As mentioned change that 22K resistor at the input of the 12AX7A to about 1.5K. (I typically use 1K in this location.) Make sure that you actually install the resistor right on pins 2 and 7 of the 12AX7A , I'm assuming that you have a single tube shared between the two channels.
The filament supply could be elevated rather than grounded to reduce noise pickup in the cathode circuit of the 12AX7A, and in fact the dc voltage present on the cathode of one of your 6V6 output tubes is ideal for this purpose.
Hopefully you have tightly twisted filament wiring with the wires not forming a loop around the socket, and tightly dressed to the chassis.
Otherwise make sure that the high voltage center tap goes directly to the negative side of your first filter cap and from there to your star ground - this will keep the cap charging currents away from everything else.
Your power transformer is not too closely mounted to the output transformers hopefully, and the core is mounted at a right angle relative to the output transformers?
Recommended reading if you don't have it already: Morgan Jones "Building Valve Amplifiers," and "Valve Amplifiers 3rd Edition."
Pictures would be great. Changes you have made so far are heading the right way.. This amplifier should sound very nice when sorted out. (I had a very similar one with 6BQ5 in my teens and it worked very well.)
www.kta-hifi.net
Old 12th February 2008, 04:49 PM   #9
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
20uF for the Plate "A" point capacitor seems pretty skimpy to me. Especially for having two single ended channels running off of it. Sure the hum may go away after adding the choke. But, it could result in a non-linear frequency response along with excessive cross talk in the lower frequencies, and intermodulation distortion.
I would simulate to make sure the rectifier won't be overloaded, but something around 220uF seems about right.
Old 12th February 2008, 06:15 PM   #10
Updated curcuit with the 1.5k grid stopper on pin 2. If it looks wrong let me know.
Circuit help jetbat Tubes / Valves 16 11th May 2009 04:23 AM
6c4 pre-amp circuit dito Tubes / Valves 2 2nd January 2007 07:42 PM
amp circuit help scott3292 Solid State 10 11th July 2005 11:16 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
What circuit? palesha Solid State 1 24th November 2002 10:18 PM
Page generated in 0.11339 seconds (83.67% PHP - 16.33% MySQL) with 11 queries
