diyAudio Sponsor
Old 11th February 2008, 07:58 PM   #1
G is offline G  United States
G's Avatar
Default Choke Input Filter.
I did some research and some calculations and came up with the design below for a 6CK4 amplifier. I was going to use a 12B4A but I can get a whopping 1/2 watt more out of a 6CK4 so I'm going in that direction. The design may be overkill but that is what I like. I only plan on building it once so why not? Anyway I am hoping for some thoughts and constructive criticism from our more learned members here.
Gavin
Old 11th February 2008, 08:04 PM   #2
SY's Avatar
Two identical LC sections can ring. Have you checked the stability in PSUD2? A current step should tell all.
edit: Just noticed the power transformer wiring. Ummmm... explosive.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 11th February 2008, 08:04 PM   #3
Seems like your power trafo is not connected correctly. Besides I recommend you give a look at pages 315 until 318 of Valve Amplifiers, 3rd edition, to see Morgan's recommendation on choke snubber networks!
Good luck, Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 11th February 2008, 08:13 PM   #4
Tweeker is offline Tweeker  United States
Id drop a choke and use an LCRC or LCRCRC with much more capacitance. Much less ringing, cheaper.
Doubt Id use a resonant choke. I absolutely would not use 2 resonant chokes, resonant chokes trade off more 100 or 120hz filtering for almost no filtering at other frequencies.
Be sure your foil hat has a good low impedance ground.
Old 11th February 2008, 08:23 PM   #5
G's Avatar
I just showed the transformer sections wired in parallel. I am using a Hammond 300 series power tranformer. I wanted to avoid confusion.
Gavin
Old 11th February 2008, 08:26 PM   #6
G's Avatar
Thanks for telling me. I designed it, crudely, from a PDF of a old tube electronics manual that I have on the 'puter. I will drop the tuning caps.
Gavin
Old 11th February 2008, 08:27 PM   #7
G's Avatar
Also the filter caps are ASC motor run caps. I can get bigger ones but I already have these at hand.
Gavin
Old 11th February 2008, 08:30 PM   #8
G's Avatar
What do I need to check? The current through the load or the current through each choke?
Gavin
Old 11th February 2008, 09:57 PM   #9
Reaction to changing current is what needs checked. This can be checked using a current step in PSUDII (use current load, edit the step, be sure to check event timings), or one can calculate the chokes damping.
Id say your better to buy more capacitance than a second choke, given the choice. While not as tough, elcos are fine sections other than the final, the R and L filter elements swamp any differences.
Be careful any chokes dont get noise coupled into them from other magnetic sources such as power supply iron.
choke input power supply filter audionut Pass Labs 49 29th January 2012 06:38 PM
Choke input filter LF noise astouffer Tubes / Valves 27 6th June 2011 11:51 PM
Choke Input Filter on Class A PS john65b Power Supplies 2 20th April 2009 10:48 AM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 05:43 PM
SOZ Choke input filter? gnomus Pass Labs 48 14th May 2004 07:41 PM
Page generated in 0.10712 seconds (77.73% PHP - 22.27% MySQL) with 11 queries
