Tube Amplifier Kit?
Tube Amplifier Kit?
Old 14th February 2008, 03:43 AM   #11
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Tube Amplifier Kit?
Originally posted by theblackknight
2 Mullard EL-84's + Mullard 12AX7
Sounds like a single ended amp to me. If you had a 12AT7 it could be an RH84.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th February 2008, 07:55 PM   #12
jamie1107 is offline jamie1107  United Kingdom
Default simple valve amps
if you can live with a little less power and use some more efficient speakers eg 95 db theses will produce a minimum of 95 db and thats alot in a room
they are very simple and cost from $150-250 depending which you choose the 1 watt or the 3.5watt
http://www.dogstar.dantimax.dk/tubestuf/miniblok.htm
http://www.dogstar.dantimax.dk/tubestuf/mnibl2-1.htm
both sound very good indeed
Tube Amplifier Kit?Hide this!Advertise here!
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 48 6th June 2013 04:51 PM
