diyAudio Sponsor
Old 8th February 2008, 05:17 PM   #1
aldovan is offline aldovan  Brazil
Default KT88 , Genalex or Chinese ? Help !!!
Friends
This KT88 is a Genalex or a cheap chinese copy ?
Thanks,
Aldovan
Old 8th February 2008, 05:54 PM   #2
I didn't think the Genelex had the metal around the base like a 6550 or am I thinking of the KT66?
Old 8th February 2008, 06:04 PM   #3
Default Do not is a KT66 tube...
Thanks for the return.
This tubes is a KT88 and have solid plates.
The base have a brown plastic as GEC.
Aldovan
Old 8th February 2008, 06:33 PM   #4
Default opinions, please...
Why the friends only read and not post ?
It is a begginer forum ?
Old 8th February 2008, 06:41 PM   #5
waltube is offline waltube  Italy
waltube's Avatar
It seems to be a GEC original, the aluminium ring base was used by this brand.
Also the mechanic is typical.
Bye
Walter
Old 8th February 2008, 07:42 PM   #6
kevinkr's Avatar
It looks a lot like some GEC KT88 I used to own. Well used I would say from the appearance or perhaps the lighting used to photograph it.
You need to be a little bit more patient, this thread was only hours old when you made your comment about people not responding. People need time to respond, and just because someone looks doesn't mean they know the answer.
These tubes have been out of production for a long, long time, and are very expensive if good. I owned more than a dozen of these at one time, I sold the last of mine over 8 yrs ago, but given the lousy picture I would not absolutely swear that is a Genelex but it sure looks like what I recollect..
www.kta-hifi.net
Old 8th February 2008, 07:53 PM   #7
diamondsouled's Avatar
There are some great pics of the original GEC Genelex tubes here:
http://www.hifiaudio.cn/en/result.js...actory=Genalex
You should be able to see if your tube is an original from these pics.
Lar
Old 8th February 2008, 11:26 PM   #8
kstagger's Avatar
GEC mica is usually fairly clear compared to the white stuff that passes as Mica these days. But the Chinese KT88 (specifically the solid plate ones) were made to look as much like GEC as possible. I'm sure my 'tube guru' friend could tell in an instance.
To me - this looks like the real deal but I can't tell w/o a better pic.
Old 9th February 2008, 04:20 PM   #9
richwalters's Avatar
Aldovan
Photo shows difference between chinese 88 and and orig NOS GEC version. The Chino has a much more profiled round top and not so pretty looking as it's older brother.
Electrically, to my suprise, the chinese version survived my slaughter test. Otherwise the internals seem sim. So many clones have polished rings and multicoloured phenol bases which don't mean anything.
richj
Old 10th February 2008, 01:04 PM   #10
Ty_Bower's Avatar
The construction of the plate and the appearance of the plate material appear to be authentic.
Notice how in the photo that Rich provided the Chinese clone tube has plates made of a "flat" looking material. The genuine MO valve has some kind of a textured appearance, probably due to the carbonizing process they used.
Here's another photo of the real deal:
Click the image to open in full size. Click the image to open in full size.
Quad Golden Lion Genalex kt88 reissues Ang Swap Meet 1 3rd August 2009 10:11 PM
FS Genalex GoldLion KT88 and KT77 nvrgdenuf Swap Meet 0 29th June 2009 04:31 PM
Genalex KT-88 reissue Salas Tubes / Valves 6 8th March 2008 05:27 AM
Cheap and Chinese KT88 SE amp andrew_whitham Tubes / Valves 46 19th May 2007 11:05 AM
6V6 Genalex gianis Swap Meet 0 8th January 2006 06:36 PM
Page generated in 0.10001 seconds (82.53% PHP - 17.47% MySQL) with 11 queries
