diyAudio Sponsor
Old 7th February 2008, 09:21 PM   #1
Default Chokes, sizing and ringing?
hi all,
I have read here numerous times how someone would post a PS and someone else would say, oooh, with those values that choke might ring. Or there isn't enough load to make that choke work etc etc.
Could someone explain exactly how a choke:
a) works
b) rings
c) works correctly/loading
and also if you have time, how to work out what H, DC resistance, mA you need with examples if possible!
I hope thats not too tall and order! There just seems to be loads of good vibes around a choke, I've seen people saying how much better a CLC is instead of a CRC etc.
Enlighten me!!
Fran
Old 7th February 2008, 09:39 PM   #2
Miles Prower's Avatar
a) works -- Depends. If this part of a CLC filter, the choke and the second capacitor form an LC low pass filter. This gives a 12db(v) rolloff above its turn-over frequency. That critical frequency is equal to:
f(c)= (LC)^-0.5 (L in henries; C in farads; f in Hz)
If it's a choke input filter, the choke serves as a constant current source into the load during the time the rectifier diodes are off. This only works with full wave rectification since the choke can't keep sourcing current long enough during the half wave off duration.
b) rings -- Coils are the leat perfect passive component. They include not only DC resistance, but also stray capacitance sinceeach turn is at a different potential from its neighbours. That leads to displacement currents, and displacement is capacitive by nature. Given that stray capacitance and the inductance of the windings, you can expect natural series and/or parallel resonances. When shock excited, the coil will ring just as if it were a tuned circuit (because that's what it is).
c) works correctly/loading -- See: Rectifier Applications Handbook for further details.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 8th February 2008, 08:39 AM   #3
MRupp is offline MRupp  Germany
MRupp's Avatar
I would recommend that you buy a copy of Morgan Jones' "Valve Amplifiers". Amongst other goodies it has a whole chapter on power supplies and chokes. I don't think anyone would want to post several pages of text to give you a full appreciation of the subject let alone enlighten you.
Martin Rupp
Old 8th February 2008, 11:10 AM   #4
G is offline G  United States
G's Avatar
I'll even give up a example for use in the discussion.
Gavin
Old 10th February 2008, 07:55 PM   #5
pchw is offline pchw  United States
In MJ's book, he mentioned that it would need approximately
(RMS input voltage) / (inductance) minimal load current in the choke input filtering. Is this still applicable to CLC? If so, what should be the RMS input voltage in this case?
Thanks!!
- Fred -
Old 11th February 2008, 01:19 AM   #6
No. The choke of a choke input filter tends to act almost as a CCS. Therefore, it requires a certain minimum of inductance to work right. If you're doing a CLC, then the choke and the capacitor behind it makes a second order LPF. You'd then size it based on how much ripple you beed to get rid of, and set the turn-over frequency accordingly:
w(c)= (LC)^-0.5 (L: henries; C: farads; w: rads/sec)
Also, make sure that w(c) occurs well below whatever minimum signal frequency you're expecting so as to avoid "filter bounce" -- a resonant phenomonon that'll absolutely ruin your voltage regulation.
The operating conditions are different as well. CLC work isn't so demanding as LC work.
www.dolphin-hsl.com
Old 11th February 2008, 04:55 AM   #7
Thank you, Miles!!
- Fred -
Old 11th February 2008, 10:13 AM   #8
OK,
thanks to you all for the info and help. I went to my trusted MJ and got the info and things are a lot clearer now!
Its a steep learning curve - and it ain't getting shallower
Fran
Sizing PP OPT alexg Tubes / Valves 14 11th June 2007 07:19 AM
Plate chokes & Power chokes JC951t Tubes / Valves 3 19th October 2006 03:18 PM
Sizing capacitors preiter Power Supplies 5 29th May 2006 04:48 AM
Sizing a Regulator cantskienuf Tubes / Valves 5 17th May 2005 03:55 AM
help w/ enclosure sizing mp3z24 Multi-Way 4 8th June 2002 12:36 AM
Page generated in 0.11013 seconds (80.67% PHP - 19.33% MySQL) with 11 queries
