| diyAudio Sponsor | ||
#11 | |
www.kta-hifi.net |
#12 | |
www.kta-hifi.net |
#13 |
Encouraged by your interest Kevin,
I plugged a chinese 12AU7 into this thing today. This fits in more easy, with less pressure and did survive the insertion. I always had the impression about the chinese tubes to go into the socket more easy and checking the pin-diameter it proved to be rather thin with .o385"". These stingy chinese guys save raw material wherever they can. The cracked ECC813 was a pre production labatory sample (otherwise similar to 6463) and did measure .o415"" at the pins. |
#14 |
.....forgot to show you my favourite 9 pin adapter
#15 |
Interesting adaptor... I haved noticed a lot of the Russian tubes also have skinnier pins as well, but oddly enough there are some current production 7868 (IIRC) that have larger pins and ruin the sockets for use with NOS types. Kind of inconsistent..
www.kta-hifi.net |
#16 | |
I now have copper (or brass) tubing in two diameters for each socket. I use a short piece of the larger diameter as the "splice" between the socket pin and a longer piece of the smaller diameter tubing which is nearly the same diameter of the socket pin and passes easilly through the PCB. For 9 pin sockets the small tubing is 1/16 inch (.062) and the larger tubing is 3/32 inch (.093). For 8 pin sockets I am using .093 and .125 inch tubing. I just soldered some 3/16 inch tubing into the PCB and soldered the 300B sockets directly to the tubing. I will post pictures of this procedure on my web site, and here if anyone is interested the next time I make some.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#17 | |
Does anyone have pics of this technique? |
#18 |
I swapped the architect for a classical musician. Life has been much better since!
#19 |
yep. Not quite as advanced as what TubeLab is talking about..
| Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? | bembel | Tubes / Valves | 12 | 11th March 2010 05:56 AM |
| Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area | baileyler | Swap Meet | 0 | 14th January 2009 02:07 PM |
| power supply schematic with a 6080 used as a "pass tube" | jarthel | Tubes / Valves | 1 | 27th May 2006 03:41 PM |
| Is it possible to get "tube sound" with just a tube preamp and chipamp output? | Spasticteapot | Instruments and Amps | 43 | 15th May 2006 05:28 PM |
| Hybrid "SE Tube Amp Sound Style" Chip Amp idea | ThorstenL | Chip Amps | 24 | 7th February 2003 06:41 AM |
| Page generated in 0.09739 seconds (81.46% PHP - 18.54% MySQL) with 11 queries |
