Tube 6N3 use pre for ChipAmp
Old 6th February 2008, 07:11 AM   #1
vthieu is offline vthieu  Viet Nam
Default Tube 6N3 use pre for ChipAmp
I have 1 tube 6N3-J , i want make pre-amp with this tube for chipamp 50w. Anyone have datasheet or schema pre-amp with this tube ? Can help me >>>Many thanks
Old 6th February 2008, 09:13 AM   #2
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
If it is the same 6N3 that you find in Russia (with nominator 6N3P), then an ECC85 or 6AQ8 is equivalent.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 7th October 2010, 10:13 AM   #3
Bone is offline Bone  United Kingdom
Ive just bought one of these on ebay which uses a pair of 6N3-Js.
Works well but gain is a little low. Traced out circuit shown below.
I assume that the gain is defined by 10K feedback resistor and 2k2 cathode resistor. Decreasing feedback should increase overall gain.
Circuit specified at rectified 150v for B+ supply. Will however give useful output if B+ is reduced to 50v
Just a suggestion.
Tony.
Old 7th October 2010, 12:56 PM   #4
dovla is offline dovla
Default 6N3=5670
6N3=6N3P=2C51=5670
Cheap 5670 currently on ebay and also Soviet 6N3P-EV can routinely be found for under $2/piece. Both sound much better than Chinese 6N3
Old 7th October 2010, 08:01 PM   #5
matejsirk is offline matejsirk  Slovenia
Default my very first diy amp
a few weeks ago I build (not yet finished):
6N3P preamp, LM3886 amp modules, ALPS pots, JantzenAudio terminals for speakers, JantzenAudio Silver cable. Sounds very good. Still working on front panel.
Next step - planning to change Wima capacitors with PIO on preamp
Old 8th October 2010, 10:53 AM   #6
feralmeida is offline feralmeida  Spain
Send a message via MSN to feralmeida Send a message via Yahoo to feralmeida
Originally Posted by dovla View Post
6N3=6N3P=2C51=5670
Hello
I also have a few 6N3P-DR, easy to find on ebay, but obviously more expensive.
About Chinese buffers 6N3, improvement is indescribable. Are 10,000 tubes use goldgrid (the meaning - DR tubes, if I am wrong, with security in NOS tubes)
but without a doubt the -EB, as you say, already provides as much improvement at low price.
All the best
Fernan
Old 8th October 2010, 11:19 AM   #7
Hi Soundbrigade
I the Germany speec, the ECC85 always try the direct replacement 6N1P,
I believe that no China or Russian 6N3, reaches values max. of the ECC85 and/or 6N1P, please correct me, If I'm wrong.
As a curiosity, in FM detection, replacing the ECC85 by 6N1P, say that the reception is better, with better sensitivity.
Greetings and
All for the best sound,
thanks to the Forum and your whole respectable participation
Fernan
Old 10th May 2011, 06:20 AM   #8
pete00t is offline pete00t  United States
Attachment 190924
Attachment 190925
Just a suggestion.
Tony.
I am new to tube audio. I wanted to start with just a little pre-amp. Is this the refined version of that amp? the circuit looks similair. It does carry a slightly beefier transformer though.
Old 8th December 2011, 10:20 PM   #9
Thatch_Ear is offline Thatch_Ear  United States
Thatch_Ear's Avatar
I just saw this
QINPU Q-2 mini HI-FI VACUUM TUBE INTEGRATED AMPLIFIER 100% BRAND - $67.39USD : Enjoy music, enjoy hifi audio!, we sell Music Angel,qinpu,yaqin,MeiXing MingDa,Bewitch,Bada Amplifiers, CD player,power amp, preamp
Looked up the tube and got a half wave rectifier which doesn't make sense. I suspect it is a mini dual triode running a chip amp with low wattage. Pretty cool for $70.
I was looking for the tube and found the amp, and this thread. Google really is changing things.
Thatch
Thatch
Old 8th December 2011, 11:03 PM   #10
A 6N3 is also a rectifier tube. The Chinese copied the Russian 6N3P double triode and called it a 6N3 just to confuse us.
Tube 6N3 use pre for ChipAmpHide this!Advertise here!
Synthesis Magnum, commercial tube-chipamp hybrid... CJ900RR Chip Amps 6 9th July 2010 03:42 PM
Project Hybrid tube-chipamp vthieu Chip Amps 0 3rd February 2008 08:40 AM
pros/cons of a chipamp VS a tube amp jarthel Everything Else 2 22nd June 2007 02:18 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 06:28 PM
lm3875 chipamp and tube pre loud buzzing webby Tubes / Valves 0 8th March 2006 01:32 PM
