diyAudio Sponsor
Old 26th February 2003, 09:12 PM   #31
Hmm..
I think that the ECL86 is the right valve for the audio stage - if you look at some of the other components, such as the IF transformers, these are also smaller (and probably more modern) than you see on late 50s/early 60s valve jobs which would place this one mid to late 60s. By this time ECL82s had been superceded.
As to finding a schematic, if this set was an export model (it is a large chassis for so few components) designed for specific markets, perhaps originally a console model, a schematic might be hard to track down.
Old 26th February 2003, 09:52 PM   #32
planet10's Avatar
ECL86 is a triode/pentode, a self contained SE power amp. The ECL82=6BM8 has been superceeded?
Actually if you can find any schematic for something similar it would probably give you a good idea of what is happening.
Birmingham? -- i was just talking to a buddy of mine (from here) that plays LooseHead for Birmingham.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th February 2003, 10:29 PM   #33
I've had a quick check through my schematics, but I have nothing for Pilot after about 1963 - possibly the brand name went into disuse in the UK, the sets being released under another name.
As regards the ECL82, its just that by the mid-1960s UK manufacturers were preferring the ECL86 for output stages in radio and gram applications, and in pp circuits also. I think the ECL82 is a good workmanlike tube, I still got a few and one or two small amps using them in pp.
Er... what's a Loosehead?
Old 26th February 2003, 10:42 PM   #34
planet10's Avatar
6BM8 was very popular with the Japanese, i haven't seen it in any European amps, and only a few US amps.
Guess that means you aren't a Rugby guy... Loosehead Prop, one of the guys on the front row in the scrum.
dave
Old 26th February 2003, 10:59 PM   #35
Dave,
I'm surprised by that - the ECL82/6BM8 was a popular choice for the output stages in UK made radios in the latter 1950s/early 1960s. I've come across them on many occasions. Also a popular choice for single tube record player amps, in hybrids sometimes using the pentode's cathode bias resistor to develop a voltage to supply a transistorised AM tuner.
So... thats what a loosehead is, and I was made (forced!) to play rugby at school. Edyerkation aint what it used to be!
Old 26th February 2003, 11:49 PM   #36
planet10's Avatar
Could because i haven't had too many UK built vintage stuff thru here... mostly German.
dave
Old 27th February 2003, 12:52 AM   #37
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Obsolessence
Time to be bored to death
As far as I can remember, the P/ECL83 was the first to go out of favour with the designers, then the P/ECL82.
The P/ECL86 was the last of the triode/pentodes with this nomenclature.
In the UK another nomenclature was also used for a parallel (though not equivalent in any sense) family of triode/pentodes:
30PL12, 30PL13, 30PL14 come to mind. The first number might be wrong, or different - it referred to the heater voltage or current.
There's more where that came from
Old 27th February 2003, 11:17 AM   #38
Default lovely old triode pentodes
Dhaen,
I think you're right, we don't need to pursue the development of the whole series of triode pentodes, otherwise we'll end up with the universal series also, the UCL82, UCL83 (but not a UCL86, at least, I've never seen one)!
What might be more useful is if anyone knows if Pilot radios were released in the UK under another brand name by the latter 1960s, because then we might be able to track down a schematic for DJev.
Old 27th February 2003, 11:43 AM   #39
diyAudio Senior Member
fdegrove's Avatar
Default PILOT RADIO.
Maybe this helps:
PILOT
Frank
Old 27th February 2003, 12:24 PM   #40
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Well, I had a look, and they all look too early. Not a hint of European valve codes. Perhaps there were two Pilots?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 02:30 PM
Philips Tube radio Grifon Tubes / Valves 5 20th September 2007 04:40 AM
Tube Radio Kit cuallito Tubes / Valves 11 29th May 2004 11:59 AM
Old russian tube radio janar74 Tubes / Valves 17 2nd June 2003 02:52 PM
Another tube radio Magnetmaz Tubes / Valves 7 11th March 2003 07:01 PM
Page generated in 0.13325 seconds (81.27% PHP - 18.73% MySQL) with 11 queries
