#11 |
Don't forget that you need output taps at 4, 8, and 16 ohms in order to supply the cathode feedback to the output tubes. I'm not sure if that can be accomplished with Lundahl transformers. I'm not saying that they cannot be used this way, just something to check into.
#12 |
After reviewing the schematic for a VT100 MKIII, I can see the OPT and other proprietary parts are going to be hard to source.
![]() So now I'm considering a modified Williamson design: http://home.att.net/~chimeraone/tube...illiamson.html Any thoughts? |
#13 | |
Unless you use absolutely top notch O/P trafos in a Williamson amp, the phase shifts will KILL you. Phase shifts are MUCH less problematic in a Mullard style circuit.
Eli D. |
| Audio research vs55/VT50/VT100 | jouch | Tubes / Valves | 2 | 7th June 2011 04:58 PM |
| ARC VT100 driver adjustment | kenneth | Tubes / Valves | 6 | 23rd January 2010 01:38 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| What amp to build? | savenger | Solid State | 2 | 4th November 2004 06:42 AM |
