| diyAudio Sponsor | ||
A friend of mine brought over this amplifier that he recently scored on eBay. It's built on a thick wall 12 inch sauce pan with EL84s and 12AX7s. The open frame OPTs and PS capacitors are mounted underneath. The power transformer is under the dome which is uniquely made from an aluminum cover that originally fit on a large compressed gas cylinder. An arch-shaped section was cut from one side and welded back on reversed 180º. This provided a light snug fit around the transformer.
I found this construction quite novel. I've seen them built on rectangular cake pans, but never a sauce pan. I didn't photograph the bottom because it was kinda sloppy with parts held on by epoxy, silicone or hot glue. Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#2 |
frugal-phile(tm)
That is well done. I have some circular pans that were aquired for the same purpose....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
That's a nice idea for the headphone amp shown in Building Valve Amplifiers, were MJ recommends to mount the valves in a circle, with a large 6AS7 in the middle!
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY! |
#4 |
Now that is actually cool looking!
How does it sound? Sal |
| Destroyer x Amplifier...Dx amp...my amplifier | destroyer X | Solid State | 7050 | 22nd May 2012 09:36 AM |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.07275 seconds (72.52% PHP - 27.48% MySQL) with 11 queries |
