diyAudio Sponsor
Old 1st February 2008, 01:56 AM   #1
Default Rectifier query
Hi all, I'm back again with another (probably quite simple) question...
I picked up a so-so, incomplete DIY amp a little while ago that somebody else made. It's ugly, real ugly--what I'm using it for, more than anything else, is a good source of spare parts
Anyway, I have traced the circuit to discover that the rectifier on the existing circuit is as illustrated in the attachment. Frankly, I'm stumped as to how it manages to work...
That is, with the two diodes wired in as they are, it would seem that this should only be a half-wave rectifier, but it's clearly not since the B+ voltage is 315V (measured). And what are the capacitors I've labelled C1 (with .01M Z5U printed on them) supposed to be doing?
I'm OK with how the B+ supplies work, I'm just a bit confused as to why this rectifier is configured the way it is, and how it manages to work. Any insight would be greatly appreciated!
(As you may have guessed, I'm not an electrical engineer )
Many thanks in advance.
Old 1st February 2008, 02:08 AM   #2
hermanv is offline hermanv  United States
This is a half wave voltage doubler. The lower 100uF capacitor is charged to the peak winding voltage by the lower diode on the first half of the sine wave. The upper capacitor is also charged to the peak winding voltage but this time by the upper diode on the second half of the sine wave. The output voltage is the sum of the two capacitor voltages and double the transformer voltage.
This kind of design has poor ripple (60Hz instead of 120HZ like a full wave bridge) and poor output regulation (double the winding Ohms and double the capacitor droop).
Old 1st February 2008, 02:12 AM   #3
Ah, I see--so it's the C1 and 100uF caps that are causing the B+ voltage to get to where it is, and the design itself that is causing some the problems I've already discovered on this unit (the poor output regulation was immediately obvious).
Thanks!
Old 1st February 2008, 02:25 AM   #4
SpreadSpectrum's Avatar
C1's purpose is to absorb diode switching noise.
Old 1st February 2008, 02:29 AM   #5
I am going to have to respectfully disagree with hermanv. This is a full wave voltage doubler and I use them all the time and like them. The thing you have to remember with them is that they double the voltage capability of the transformer but they also halve the current capability. (you can't get something for nothing)
Old 1st February 2008, 02:33 AM   #6
Furthermore, if you are charging the top capacitor on one half of the AC cycle and charging the bottom capacitor on the other half of the AC cycle, you have to get 120Hz ripple. Correct me if I am wrong.
Old 1st February 2008, 03:51 AM   #7
SpreadSpectrum is correct. That topology is known as a full wave voltage doubler. Some justification for the name exists. The ripple freq. is 2X that of the AC mains and both halves of the sine wave are used.
Properly executed, "full wave" doubler B+ PSUs are quite good. Some of the best units ever made employ the topology. The H/K Cit. 2, Marantz 8B, and Fisher 500C are examples.
LARGE caps. are appropriate in the doubler stack. Large 1st filter caps. imply a small conduction angle and a good deal of ripple overtone energy. Follow the doubler stack with a low DCR inductance and more capacitance. Think "extended" CLC filter. A H/K Cit. 2 overhauled ala Jim McShane kicks serious butt. Jim replaces the OEM doubler caps. with low ESR 820 muF. Panasonic 'lytics. The rest of the B+ PSU is beefed up too.
FWIW, we used something quite similar, at a lower current, in "El Cheapo" and (unsurprisingly) obtained highly satisfactory performance.
TANSTAAFL applies and the available DC current is approx. 1/4 the AC RMS current of the rectifier winding.
Eli D.
Old 1st February 2008, 04:19 AM   #8
Yeah, a google search revealed that I have a full-wave doubler here, not a half wave, but that's OK.
However, the poor voltage regulation is a very real thing--I worked out the transfer function for the whole thing, and compared the actual (measured) results with the computed ones (assuming a true DC input signal) to find some reasonably large discrepancies. This is now easily explained by both the 100 Hz ripple current (2x AC mains frequency) and the undersized caps. The two factors combined effectively mean that the filtering is less than what it needs to be.
Either way, I have once again learned a bundle--best forums ever
As well, I'm planning on doing things differently in the upcoming build anyway--full wave rectification via an RCA 82, with the input coming from a purpose built transformer (no voltage doubler or anything).
Old 1st February 2008, 04:44 AM   #9
Yep, you guy's are right (damn ) it is a full wave and as a result the ripple is 120Hz (ripple from lower Capacitor interleaves with ripple from upper capacitor)
Old 1st February 2008, 04:47 AM   #10
@hermanv: Not your day today, as 2x 50Hz = 100Hz
UK Law query john blackburn The Lounge 35 15th May 2009 09:59 AM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
6CJ3 rectifier or 6D22S rectifier 56oval Tubes / Valves 10 19th April 2007 09:48 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.10428 seconds (80.22% PHP - 19.78% MySQL) with 11 queries
