diyAudio Sponsor
Old 22nd February 2011, 11:51 AM   #21
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
Isn't .5mm lamination too thick for and output?
i use them for power transformers and guitar amp outputs......
Old 22nd February 2011, 11:53 AM   #22
Tony's Avatar
I though one would never build an audio trafo with at least .35 lamination (M6)
The frequency response will be limited by the core lamination, I don't think they can sound very good...
at our side of the world, 0.35mm lams are called Z11, an M6 equivalent.....i used them to build output traffos....
Old 22nd February 2011, 12:48 PM   #23
Originally Posted by kevinkr View Post
A dcr of 1.1 ohm on the 8 ohm tap is actually a pretty good result, I've not seen many that were better including the Tamura F-5002 (about 1 ohm) I used in some projects.
The last amorphous core output transformer for the 300B I made had:
primary DC resistance 58 ohm,
secondary DC resistance (8ohm) 0,13 ohm,
Primary inductance (static measurement) 25 H.
Low resistance windings are really very important; I don't understand why people take mediocre or worse output transformers to mate with what is regarded one of the best output tubes, but yes I know: output transformers don't glow....
For that Chinese OPT: take a triode connected EL34 or something like that, with a 300B the tube is "a flag on a **** boat" (translation of Dutch saying....).
Old 22nd February 2011, 04:14 PM   #24
Yvesm is offline Yvesm  France
Yvesm's Avatar
No sure that a triode connected EL34 is worst than a Chinese 300B when inserted between a clean driver and a decent OPT
I agree, it shines less !
Yves.
Best SE output transformer for 300b - shootout andyjevans Tubes / Valves 39 13th October 2010 01:50 AM
300B Transformer temperature peter7 Tubes / Valves 7 27th September 2008 04:12 PM
Where in Brisbane can I get a transformer for my Chinese amp data Tubes / Valves 7 17th February 2008 08:50 AM
GTA 300B SE Mk.II Power Transformer korneluk Tubes / Valves 4 17th December 2007 05:09 PM
Best output transformer for 300B hnb2907 Tubes / Valves 8 4th December 2007 04:14 PM
Page generated in 0.07364 seconds (72.68% PHP - 27.32% MySQL) with 11 queries
